29276 Discussions
Redirecting Fortran DLL's output to an external file
ale_a
Hello everyone,
I don't know how to solve the following problem:
In the main program I call a subroutine contained in a Fortran DLL ('HAPauto'), which in turn calls another DLL that performs calculations and prints a lot of data to the screen (command-line console).
I'd like to redirect its output to an external file. I have tried to set the FOR_PRINT environmental variable (see commented statements below), but it doesn't affect the DLL's behavior. Here is my basic code:
PROGRAM main
!DEC$ ATTRIBUTES DLLIMPORT :: HAPauto
!DEC$ ATTRIBUTES ALIAS:'HAPauto' :: HAPauto
! USE IFPORT
! LOGICAL res
! res = SETENVQQ('FOR_PRINT=HAPresults.dat')
CALL HAPauto
END PROGRAM MAIN
Thank you very much for any suggestions.
Alessio
P.S. Intel Visual Fortran Compiler Version 10.1.011
Most likely the fix is to set the main program project property Fortran > Libraries > Use Runtime Library to "Multithreaded DLL". If you don't do this, opening a file in the main program won't be recognized in the DLL.
However... If the DLL does PRINT, you can't, in 10.1, open the unit for PRINT, so that may not help. I think that the FOR_PRINT test happens before your main program runs.
Can you change the DLL to WRITE to unit 6? Then you can open unit 6 and the DLL will use it.
ale_a
Hello Steve,
thank you for your prompt reply. I have tried to use the "Multithreaded DLL" option, but unfortunately your prediction was correct: it didn't help.
I cannot change the DLL to WRITE to unit 6. It's legacy code that I was given, so I guess I don't have any other viable options, right...?
Which compiler version should I have to be able to open the unit for PRINT?
Thank you again.
Alessio
Can you rebuild the DLL using 11.1? If you can, and add /assume:noold_unit_star, then if you open unit 6 in the main program, the DLL will use unit 6 for the PRINT. You will need to build the main with Multithreaded DLL.
ale_a
I will see if I can manage to go this way.
Thanks a lot for your excellent support.
Alessio
