29255 Discussions
Redistributable merge module (.msm) file for 11.1.065 version of redistributable libraries?
Gile__Clint
Is a redistributable merge module (.msm) file available for the Intel Visual Fortran Compiler for Windows 11.1.065 update 6  Redistributable library package for IA32?
(I only seem to be able to find the zip archive: w_cprof_p_11.1.065-redist_ia32.zip on the Redistributable libraries for the Intel® C++ and Visual Fortran Compiler 11.1 for Windows page of links.)
Steven_L_Intel1
I am not sure if we were doing merge modules in 11.1. When we have an msm for the redist, it's also under the redist folder in the installation directory.
Gile__Clint
If not (it isn't there), is there any possibility one could be created?
Steven_L_Intel1
No,sorry. But there's no reason not to use a .msm from a more recent version. Our run-time DLLs are upward compatible.
Gile__Clint
OK, I will give that a try -- thanks.
Steven_L_Intel1
You'll need an MSVC redistributable msm as well.
Chris_W_5
After installing w_fcompxe_redist_ia32_2015.2.179.msi the redist folder does not appear to have a .msm file. Does this mean that there is no .msm file for this version of the redistributable. The file path I am using to look for the merge module is C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist.
Chris
Steven_L_Intel1
The redist download doesn't include the msm. Installing the compiler does, or you can download the msm from the Intel Registration Center (listed alongside the redistributable executable installer.) You will never see the msm under Common Files. It will be in the compiler install folder under "redist\ia32\compiler" or "redist]intel64\compiler".
