Is a redistributable merge module (.msm) file available for the Intel Visual Fortran Compiler for Windows 11.1.065 update 6 Redistributable library package for IA32?
(I only seem to be able to find the zip archive: w_cprof_p_11.1.065-redist_ia32.zip on the Redistributable libraries for the Intel® C++ and Visual Fortran Compiler 11.1 for Windows page of links.)
I am not sure if we were doing merge modules in 11.1. When we have an msm for the redist, it's also under the redist folder in the installation directory.
If not (it isn't there), is there any possibility one could be created?
No,sorry. But there's no reason not to use a .msm from a more recent version. Our run-time DLLs are upward compatible.
OK, I will give that a try -- thanks.
You'll need an MSVC redistributable msm as well.
After installing w_fcompxe_redist_ia32_2015.2.179.msi the redist folder does not appear to have a .msm file. Does this mean that there is no .msm file for this version of the redistributable. The file path I am using to look for the merge module is C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist.
Chris
The redist download doesn't include the msm. Installing the compiler does, or you can download the msm from the Intel Registration Center (listed alongside the redistributable executable installer.) You will never see the msm under Common Files. It will be in the compiler install folder under "redist\ia32\compiler" or "redist]intel64\compiler".
