29278 Discussions
Reduction clause in OpenMP with ifort
gottoomanyaccounts
Dear forum,
I am trying to use the 'reduction' clause with ifort version 11.1.038, but get segmentation fault error. I have been trying with the version ifort 10.1 in the past, out of luck too.
I am attaching the code at then end, the code was compiled with
ifort -warn all -check all -openmp -o reduction.x reduction.f90
Any help is much appreciated. Thanks.
file reduction.f90:
program test_reduction
integer, parameter :: n=100
real :: r = 0.45
real, dimension(n,n,n) :: a, summ
integer :: i,j,k
summ = 0.
!$OMP PARALLEL DO &
!$OMP default(shared) &
!$OMP reduction(+: summ) &
!$OMP private(i,j,k)
do i = 1,n
do j = 1,n
do k = 1,n
a(i,j,k) = (i+j)/k
summ(i,j,k) = summ(i,j,k) + a(i,j,k)*r
enddo
enddo
enddo
!$OMP END PARALLEL DO
write(*,*) summ
end program
TimP
Your reduction variable must be a scalar. Alternatively, you could remove the reduction clause, and your code would have a meaning, but not a reduction.
Without OpenMP, you might expect ifort to optimize the loop nesting, at least at -O3, but the OpenMP would probably prevent optimization.
gottoomanyaccounts
Quoting - tim18
Thanks for the answer. Is 'the reduction variable must be a scalar' the OpenMP standard? My impression is I have seen examples using reduction array..
The above code is what I used to test the reduction clause, in reality, the different private loops are likely to sum to the same array position; in this case, simply removing the reduction clause will result in race condition, right? What is the recommended solution in this situation? Thanks a lot.
TimP
When you store to different array elements in each thread, as you have written it, there is no race, and no reduction. Reduction is for combining results from multiple threads, where, as you say, if multiple threads tried to add directly to a single variable, without reduction or critical section, there would be a race.
You could do in effect a reduction from rank 3 to rank 2. I don't see why you would use an OpenMP reduction operation for that, as you would want each thread to have its own results, no race with the other threads.
It looks like you are saying that what you show here doesn't represent your actual problem, which may be one which isn't reliable to parallelize.
gottoomanyaccounts
Quoting - tim18
That's correct. My actual code looks like something like this
do m = 1, N
i = f(m) ! i is a function of m
j = g(m) ! j is another function of m
s(i,j) = s(i,j) + a(i,j)
enddo
Different m values may result in the same (i,j), so what should I do in this case?
jimdempseyatthecove
do m = 1, N
enddo
Do your own reduction of array
[cpp]s = 0.0
!$omp parallel private(i,j,m,sLocal)
sLocal = 0.0
!$omp do
do m = 1, N
enddo
!$omp end do
!$omp critical
s = s + sLocal
!$omp end critical
!$omp end parallel
[/cpp]
Jim Dempsey
jimdempseyatthecove
Note, if s is large, replace the critical section with nested loops containing a barrier. With each thread working on a different section of the array.
me = omp_get_thread_num()
do j=1,jMax
mej = me+j
if(mej .gt. jMax) mej = mej - jMax
do i=1,iMax
s(i,mej) = s(i,mej) + sLocal(i,mej)
end do
!$omp barrier
end do
Jim Dempsey
