Referencing a function from outside as well as inside when creating a DLL
Syed_R_
I am creating a DLL.
I have a function that will be referenced from outside as well as inside.
For it to be referenced from outside, I have used DLLEXPORT. But then the inside referenced don't link and conplain with LNK2001 error i.e. unresolved external symbol for that function.
How can I fix this situation? Please help!
Syed_R_
Just want to add to this that I am using ALIAS in the DLLEXPORT with the same name as the function name.
Steven_L_Intel1
DLLEXPORTing the name shoudn't prevent referencing it from inside the DLL. However, if you used ALIAS (why?), you'd have to also use ALIAS in a declaration visible to any code that calls this routine - unless the routine was in a module in which case all you need do is USE the module.
