I have a test case where ifx 2025.1.1 is aborting with "error #5633: **Internal compiler error". This is a Linux system (both SLES and RHel fail). This is a REGRESSION, as ifx 2025.0.0. and earlier compilers are able to compile the test without a failure. I have attached the reduced test case. Here is the error output:
$ ifx --version
ifx (IFX) 2025.1.1 20250418
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
$ ifx -c cmp.F90
#0 0x00000000033106d1
#1 0x00000000033754d7
#2 0x0000000003375605
#3 0x00007fa74ef1d900
#4 0x00000000028a37d1
#5 0x00000000028a35f7
#6 0x000000000227194f
#7 0x00000000028a21bd
#8 0x00000000028a0c2c
#9 0x00000000028a27dc
#10 0x00000000028a5dc2
#11 0x00000000028a66d1
#12 0x00000000028a5800
#13 0x00000000028a5ff8
#14 0x00000000028a6e1c
#15 0x00000000024f8995
#16 0x00000000024f8201
#17 0x00000000024f1f38
#18 0x00000000024f1c71
#19 0x000000000252cd65
#20 0x000000000252cb41
#21 0x00000000024f743a
#22 0x00000000032ae3da
#23 0x00000000032abf23
#24 0x0000000003256251
#25 0x0000000003433c98
#26 0x00007fa74ef06e6c
#27 0x00007fa74ef06f35 __libc_start_main + 135
#28 0x000000000308f34e
/tmp/ifx1281730237bYOBQW/ifx3AxWPF.i90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for cmp.F90 (code 3)
Here is ifx 2025.0.0 able to successfully compile the program:
$ ifx --version
ifx (IFX) 2025.0.0 20241008
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
$ifx -c cmp.F90
$ ls -l cmp.o
-rw-r--r-- 1 geir compiler 45576 Nov 21 15:01 cmp.o
In my Ubuntu system that code compiled OK with ifx 2025.3.0 20251010.
Thank you very much! Did you happen to see if it failed use Intel 2025.1?
