29362 讨论
Regression: Intel Fortran 2025.1 aborting with error #5633: **Internal compiler error
geir
初学者
275 次查看
I have a test case where  ifx 2025.1.1 is aborting with "error #5633: **Internal compiler error".  This is a Linux system (both SLES and RHel fail).  This is a REGRESSION, as ifx 2025.0.0. and earlier compilers are able to compile the test without a failure.  I have attached the reduced test case.  Here is the error output:
$ ifx --version
ifx (IFX) 2025.1.1 20250418
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
$ ifx -c cmp.F90
          #0 0x00000000033106d1
          #1 0x00000000033754d7
          #2 0x0000000003375605
          #3 0x00007fa74ef1d900
          #4 0x00000000028a37d1
          #5 0x00000000028a35f7
          #6 0x000000000227194f
          #7 0x00000000028a21bd
          #8 0x00000000028a0c2c
          #9 0x00000000028a27dc
         #10 0x00000000028a5dc2
         #11 0x00000000028a66d1
         #12 0x00000000028a5800
         #13 0x00000000028a5ff8
         #14 0x00000000028a6e1c
         #15 0x00000000024f8995
         #16 0x00000000024f8201
         #17 0x00000000024f1f38
         #18 0x00000000024f1c71
         #19 0x000000000252cd65
         #20 0x000000000252cb41
         #21 0x00000000024f743a
         #22 0x00000000032ae3da
         #23 0x00000000032abf23
         #24 0x0000000003256251
         #25 0x0000000003433c98
         #26 0x00007fa74ef06e6c
         #27 0x00007fa74ef06f35 __libc_start_main + 135
         #28 0x000000000308f34e
/tmp/ifx1281730237bYOBQW/ifx3AxWPF.i90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for cmp.F90 (code 3)
Here is ifx 2025.0.0 able to successfully compile the program:
$ ifx --version
ifx (IFX) 2025.0.0 20241008
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
$ifx -c cmp.F90
$ ls -l cmp.o
-rw-r--r-- 1 geir compiler 45576 Nov 21 15:01 cmp.o
0 项奖励
2 回复数
JFH
新分销商 I
244 次查看
In my Ubuntu system that code compiled OK with ifx 2025.3.0 20251010.
geir
初学者
84 次查看
Thank you very much!  Did you happen to see if it failed use Intel 2025.1?
0 项奖励
回复
