29282 Discussions
Regression for IFORT 2021.7.0 with parameter and constructor
Wolf_W_
I stumbled upon a compiler bug. The following code worked with former compilers but crashes during compilation now (ifort 2021.7.0 / oneAPI 2022.3.1).
module M_BAR
  type, public :: T_BAR
      integer, public :: member(3) = [0,0,0]
  end type
  type, public, extends(T_BAR) :: T_BAR_HELPER
  end type
#if 0
!Workaround
  type(T_BAR_HELPER), parameter, public :: OBJ_123_help = T_BAR_HELPER([1,2,3])
  type(T_BAR),        parameter, public :: OBJ_123      = OBJ_123_help%T_BAR
#else
  type(T_BAR),        parameter, public :: OBJ_123      = T_BAR([1,2,3])
#endif
  interface T_BAR
    module procedure constructorExtension
  end interface
contains
  pure function constructorExtension(a,b,c)
    integer, intent(in) :: a,b,c
    type(T_BAR) :: constructorExtension
    constructorExtension%member(:) = [a,b,c]
  end function constructorExtension
end module
program TESTPROG
use M_BAR
  type(T_BAR) :: BB = OBJ_123
  type(T_BAR) :: CC
  CC = OBJ_123
  write(*,*)CC%member(:)
end program TESTPROG
It seems to be a problem with the constructor interface. It works to without the interface, but that would break a lot of code in my case. The workaround with the dummy-type seems to work so far.
Greetings
Wolf
TobiasK
good news, finally the fix made it into release 2023.1. Please try it on your side.
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Best
Tobias
FortranFan
@Wolf_W_ ,
Take it that an internal compiler error (ICE) in encountered now and that's what you mean by, "The following code worked with former compilers but crashes during compilation .."?
ICEs are pernicious and it may help to state them as much if that's what you face to get added attention.
Ron_Green
We have been working on constructors.  I'll take and look.
TobiasK
Hi Wolf,
thank you for reporting this to us and for the clear and simple reproducer.
I have escalated the issue internally and will track the status for you.
(CMPLRLLVM-41963)
Best
Tobias
TobiasK
Hi Wolf,
happy new year!
We fixed the ICE in our internal builds and it will be part of a future release. I will come back to you as soon it is released.
Thanks again for reporting the issue to us!
Best
Tobias
TobiasK
Best
Tobias
