This minimal reproducer used to compile with XE2018U3, but not in the initial XE2019 release; I have submitted a support case (#03656010) to Intel:
module engine_params
implicit none
public
! Kinds for real and doubles
integer, parameter :: sp = kind(0.0), dp = kind(0.0d0)
end module
module m_mod
use engine_params, only: dp
implicit none
private
save
type, public :: cubic_coeffs
private
real(dp) :: c(0: 3)
end type
type, public :: m_t
private
real(dp) :: var
! Cubic equation coefficients
type(cubic_coeffs), allocatable, dimension(:) :: eqn
contains
procedure, public :: sub
end type
interface
module subroutine sub(this)
class(m_t), intent(inout) :: this
end subroutine sub
end interface
end module
submodule (m_mod) m_submod
implicit none ! all variables must be defined
contains
integer :: nincs
nincs = size(this%eqn) + 1
call sub_sub
contains
subroutine sub_sub
real(dp) :: cogtable(nincs)
cogtable = 0
this%var = cogtable(nincs - 1)
end subroutine
end subroutine
end submodule
program xe2019_1
use m_mod
implicit none
end program
From VS2015:
1>------ Rebuild All started: Project: XE2019_1, Configuration: Debug Win32 ------ 1>Deleting intermediate files and output files for project 'XE2019_1', configuration 'Debug|Win32'. 1>Compiling with Intel(R) Visual Fortran Compiler 19.0.0.117 [IA-32]... 1>engine_params.f90 1>m_mod.f90 1>m_submod.f90 1>D:\Source\VS Projects\XE2019_1\XE2019_1\m_submod.f90(14): error #6683: A kind type parameter must be a compile-time constant. [DP] 1>compilation aborted for D:\Source\VS Projects\XE2019_1\XE2019_1\m_submod.f90 (code 1) 1>xe2019_1.f90 1> 1>Build log written to "file://D:\Source\VS%20Projects\XE2019_1\XE2019_1\Debug\BuildLog.htm" 1>XE2019_1 - 2 error(s), 0 warning(s) ========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
