Regression with fpp 2025.2.0
Matt_Thompson
A library I help maintain cannot be compiled by ifx 2025.2.0 because there seems to be a bug in fpp 2025.2.0
An example is this code:
#define __VERIFY__(a) if(internal_verify(a,rc=rc)) return
#define __RC__ rc=status); __VERIFY__(status
foo(__RC__)
This is a *very* whittled down version of what the actual code is, but it demonstrates the issue.
To wit, using fpp 2025.2.0:
> fpp -V
Intel(R) Fortran Preprocessor for applications running on Intel(R) 64, Version 2025.2.0 Build 20250605
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
^C
> fpp Lexer.F90
# 1 "Lexer.F90"
Lexer.F90(3): #error: number of arguments doesn't match.
foo(rc=status); if(internal_verify(status,rc=rc)) return
> echo $?
1
Now we use fpp 2025.1.0:
> fpp -V
Intel(R) Fortran Preprocessor for applications running on Intel(R) 64, Version 2025.1.0 Build 20250317
^C
> fpp Lexer.F90
# 1 "Lexer.F90"
> echo $?
0
Note that the preprocessor returns the exact same code but fpp 2025.2.0 returns an error message and a non-zero-status code. Thus, ifx halts since fpp is failing.
I will also say every other preprocessor I've tried works as well. cpp:
> cpp --version
cpp (GCC) 15.1.0
Copyright (C) 2025 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> cpp Lexer.F90
# 0 "Lexer.F90"
# 0 "<built-in>"
# 0 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 0 "<command-line>" 2
# 1 "Lexer.F90"
> echo $?
0
and NAG Fortran:
> nagfor -V
NAG Fortran Compiler Release 7.2(Shin-Urayasu) Build 7228
Product NPL6A72NA for x86-64 Linux
Copyright 1990-2024 The Numerical Algorithms Group Ltd., Oxford, U.K.
> nagfor -F Lexer.F90
> echo $?
0
> cat Lexer.f90
# 1 "Lexer.F90"
And, as before, the resulting processed code is always the same.
I suppose I could do something like:
ifx -fpp-name=/path/to/cpp
but I'm not sure if cpp does all the same stuff fpp does and if we are relying on some fpp-only macro.
Matt_Thompson
Update. It looks like fpp 2025.2.1 does NOT fix this, sadly:
> cat test.F90
foo(__RC__)
> fpp -V
Intel(R) Fortran Preprocessor for applications running on Intel(R) 64, Version 2025.2.1 Build 20250806
^C
> fpp ./test.F90
# 1 "test.F90"
test.F90(3): #error: number of arguments doesn't match.
> echo $?
1
