Relocation truncated to fit
wongyung
Hi
I hope people can help me with a problem I am having. I keep on getting this error message when I try to compile my program:
ifort NRTYPE.F90 debug2.f90 factorial.f90 comp_2_arrays.f90 population_c.f90 pop_fluctuation2_c.f90 get_rho2.f90 -check all -o BH_Ar6 BH_Ar6.f90 -L/home/wy/ARPACK/ -larpack_OPT -L$MKL -lmkl_lapack -lmkl_em64t -lguide -lpthread
/tmp/ifortkvUiEu.o(.text+0x1dd5): In function `MAIN__':
BH_Ar6.f90: relocation truncated to fit: R_X86_64_PC32 against `.bss'
/tmp/ifortkvUiEu.o(.text+0x1dfe):BH_Ar6.f90: relocation truncated to fit: R_X86_64_PC32 against `.bss'
There's more but it's on the same lines.
I have tried what some people have suggested about using -i-dynamic and -mcmodel=large and it doesn't help. It does change the error message though:
ifort NRTYPE.F90 debug2.f90 factorial.f90 comp_2_arrays.f90 population_c.f90 pop_fluctuation2_c.f90 get_rho2.f90 -check all -mcmodel=large -i-dynamic -o BH_Ar6 BH_Ar6.f90 -L/home/wy/ARPACK/ -larpack_OPT -L$MKL -lmkl_lapack -lmkl_em64t -lguide -lpthread
/home/wy/ARPACK//libarpack_OPT.a(znaupd.o)(.text+0x59): In function `znaupd_':
znaupd.f: relocation truncated to fit: R_X86_64_PC32 against symbol `debug_' defined in COMMON section in /home/wy/ARPACK//libarpack_OPT.a(znaupd.o)
/home/wy/ARPACK//libarpack_OPT.a(znaupd.o)(.text+0x70):znaupd.f: relocation truncated to fit: R_X86_64_PC32 against `.bss'
And more on the same lines.
I am running SUSE 9.2 Professional with Intel Fortran compiler:
Version 9.0 Build 20050430
My system is a dual Opteron.
Thanks in advance for any help!
TimP
I don't know if -check all is always practical for large programs.
You are using a rather old version of the compiler. However, if you change to a compiler with a newer version of libguide than your MKL, it's better to link the libguide which comes with the compiler.
-O1 might help, particularly if you want to use -xW.
wongyung
Resurrecting an old thread with new developments.
OK, from the compiler output as seen on the 1st post, it clearly looks like the problem is with ARPACK. I recompiled arpack with "-mcmodel=large -i-dynamic" and voila the compiler errors related to arpack disappeared...to be replaced by the same "relocation truncated to fit" messages for mkl:
/opt/intel/mkl721/lib/em64t/libmkl_lapack.a(zhetrd_omp.o)(.text+0xebf): In function `_mkl_lapack_zhetrd_347__par_region2':
ker_zhetrd_omp.f: relocation truncated to fit: R_X86_64_PC32 against `.bss'
/opt/intel/mkl721/lib/em64t/libmkl_lapack.a(zhetrd_omp.o)(.text+0x11d0):ker_zhetrd_omp.f: relocation truncated to fit: R_X86_64_PC32 against `.bss'
So it seems that the mkl libraries are not compiled with the large or medium memory profile options. Unfortunately, unlike arpack I can't exactly recompile the intel mkl libraries myself.
So does anyone have any ideas on what I can do?
Steven_L_Intel1
I'd suggest you ask in the MKL section of the forum.
