29653 Discussions
Removing debug info when compiled with debug
sgongola
Is there a way to remove debugging information from an obj, lib, dll or exe if the item was originally created with debugging information enabled? Maybe something like the unix strip command?
thank you
sol
Most of the debugging information is in a separate PDB file, so I don't think this is too useful.
sgongola
Compile was done with /nopdbfile.
Also: can the /dbglibs compile option be overridden in a subsequent link step?
With a PDB file, does the object still have some debug information in it.
thank you
sol
I think with PDB. all the info is in the PDB. I suppose you can re-link with /nodebug. I don't know of a strip tool.
You can use the linker's /NODEFAULTLIB option to tell it to ignore all the default libraries, or specific ones, then supply the ones you want.
