Removing dependency on imagehlp from DLL
Bonnie_J_1
I am trying to create a DLL that will be used on a "Windows-like" operating system, and unfortunately the OS does not have imagehlp.dll.
Is there a way to remove my DLL's dependency on imagehlp.dll? I've compiled in release mode and have tried to disable all debugging/traceback options. However, I still get references to StackWalk, SymCleanup, and SymInitialize.
I'd appreciate any advice you can give!
Anthony_Richards
Have you tried using the free Dependancy Walker application to find what is requiring IMAGEHLP.DLL to be loaded P.S. to Intel, How do I delete my own posts?
Steven_L_Intel1
IMAGEHLP.DLL is referenced by the traceback code. Perhaps it would work to delay-load that DLL. In Linker > Input, set property Delay Loaded DLLs to IMAGEHLP.DLL . Then add delayimp.lib to "Additional Dependencies". If nothing ever calls into IMAGEHLP it won't be required. Anthony, as for deleting your own posts, I think it is available until there is a reply. You can ask an Intel person to do it.
