29487 Discussions
Removing trailing blanks from a string - not TRIM or ADJUSTR/L
IDZ_A_Intel
Hi folks
Can someone shed some light on how to remove the trailing blanks from a character string please?
I thought TRIM would do the trick but that just counts the characters minus the trailing blanks - I want to keep the character string as a string, just without the blanks. UDJUSTR/L also seemed promising at first, but they simply move the blanks around and do not remove them.
I assume the apparent trouble I'm having with this is because a string, once declared as a particular size, cannot easily have its length changed (if at all???).
Thanks!
Arjen_Markus
No, in Fortran (at least up to and including Fortran 95) a string has a fixed length. In Fortran 2003 you can define character strings with an allocatable length. An alternative is to use the iso_varying_length module (here is one version: http://www.fortran.com/iso_varying_string.f95, my Flibs project athttp://www.flibs.sf contains another implementation). This is mean to overcome the fixed length limitation of strings in Fortran 90/95.
Depending on what you want to do exactly, however, you can also use ordinary strings in this manner:
subroutine use_a_flexible_string( length )
character(len=length) :: string
end subroutine
This routine defines the length of the local variable string dynamically. The calling program determines what length to use.
Arjen
Arjen_Markus
Oops, the correct URL for Flibs is: http://flibs.sf.net
Arjen
rase
Take a look at John Burkhard's library pages, especially the chrpak collection:
(http://people.sc.fsu.edu/~burkardt/f_src/chrpak/chrpak.html).
Many subroutines do various tricks with character strings. Maybe you find there what you are looking for.
As others have said, a normal character variable in Fortran has a fixed length. You can use TRIM when passing a string as an argument or in an expression, but if you assign the value to a variable you'll get the blanks back.
Intel Fortran 11.1 does support deferred-length allocatable character variables which I would recommend over the ISO_VARYING_STRING package. An example:
[fortran]character(:), allocatable :: str
str = 'abcde'
print *, len(str)  ! Prints 5
str = '123456789'
print *, len(str)  ! Prints 9
str = 'The Quick Brown Fox      '
str = trim(str)
print *, len(str)  ! Prints 19
end[/fortran]
