I am sorry that I can't reply to the original post.
The interface of 'writestring' is as follows:
subroutine writestring(filename,msg) bind(c,name='writestring')
use iso_c_binding
implicit none
type(c_ptr),value::filename,msg
end subroutine
After I replaced 'C_LOC' by 'LOC', the following error displayed:
So I think it can't be replaced.
error #6633: The type of the actual argument differs from the type of the dummy argument. [LOC]
Tang Laoya
The type returned by LOC is integer of size of 4 or 8 depending on 32 or 64 bit build
Whereas the type returned by C_LOC is C_PTR.
You have to be consistent with regards to argument type (in INTERFACE and CALL (and receiver function)) even though the bit patters may be the same.
Jim Dempsey
In the interface, replace "type(c_ptr), value" with "character, dimension(*)". In the call, simply remove the C_LOC or LOC.
