29487 Discussions
Restriction on STDCALL Attribute with ENTRY Points
wkramer
Since version 10.0 a procedure entry and the procedure must have the same use of the STDCALL attribute.
I used the following code to assure that procedure and entry points all have the STDCALL attribute:
!DEC$ IF DEFINED (_DLL)
!DEC$ATTRIBUTES DLLEXPORT :: VISCOS,VISL,VISV
!DEC$ATTRIBUTES STDCALL, REFERENCE, ALIAS: 'VISCOS_DLL' :: VISCOS
!DEC$ATTRIBUTES STDCALL, REFERENCE, ALIAS: 'VISV_DLL' :: VISV
!DEC$ATTRIBUTES STDCALL, REFERENCE, ALIAS: 'VISL_DLL' :: VISL
!DEC$ ENDIF
However, I still get the following error messages
E:IVFIF97SourceTrpprop.for(60) : Error: A procedure entry and the procedure must have the same use of the STDCALL attribute.   [VISL]
      ENTRY VISL(Pin,Tin)
E:IVFIF97SourceTrpprop.for(65) : Error: A procedure entry and the procedure must have the same use of the STDCALL attribute.   [VISV]
      ENTRY VISV(Pin,Tin)
The compiler settings are:
Compiling with Intel Fortran Compiler 10.1.013 [IA-32]...
ifort /nologo /Zi /Od /gen-interfaces /warn:interfaces /Qauto /Op /fpconstant /iface:mixed_str_len_arg /module:"Debug/" /object:"Debug/" /traceback /check:bounds /c /DLL /debug-parameters /Qvc7.1 /Qlocation,link,"D:Microsoft Visual Studio .NET 2003Vc7in" "E:IVFIF97SourceWrapper.for"
I have used these settings succesfully under 9.1
Any idea what I am doing wrong?
Walter Kramer
I'd want to see the actual source before I could comment.
The reason for the restriction is that otherwise the compiler would have to track through which entry point you entered in order to determine how to exit.
wkramer
Steve,
I hope the following piece of code can help you detect where the problem is.
Walter Kramer
REAL(8) FUNCTION VISCOS(Vin,Tin)
USE STMCOM
IMPLICIT REAL(8)(A-Z)
REAL(8), INTENT(IN) :: Vin,Pin,Tin
INTEGER(4) Ilim
INTEGER(4) L
CHARACTER*8 NAME
CHARACTER*8, SAVE :: NAMEold
REAL(8), SAVE :: Fval,Arg1=-1.D3,Arg2=-1.D3
Emsg=.FALSE. ! DON'T SEND ERROR MESSAGES
!DEC$ ENDIF
NAME='VISCOS'
UC=UCin
V=Vin*Vcnv(UC)
T=(Tin+Tcnv2(UC))*Tcnv1(UC)
CALL STMLVL(NAME,V,T)
IF ((V.EQ.Arg1).AND.(T.EQ.Arg2).AND.(NAME.EQ.NAMEold)) GOTO 100
CALL MINMAXVT(V,T,Vlow,Vhigh,Tlow,Thigh)
GOTO(1000) ICHKLIM(V,Vlow,Vhigh,
& T,Tlow,Thigh,Xlim,Ylim,Ilim)
!DEC$ ELSE
IF ((T.LT.TMIN).OR.(T.GT.T5MAX+0.01D0)) GOTO 400
IF ((V.LT.VMIN).OR.(V.GT.V5MAX)) GOTO 400
!DEC$ ENDIF
Arg1=V
Arg2=T
NAMEold=NAME
Fval=VISC(1.D0/V,T)
GOTO 100
ENTRY VISL(Pin,Tin)
L=1
NAME='VISL'
GOTO 10
ENTRY VISV(Pin,Tin)
L=0
NAME='VISV'
10
CONTINUE
UC=UCin
P=Pin*Pcnv(UC)
CALL STMLVL(NAME,P,T)
IF ((P.EQ.Arg1).AND.(T.EQ.Arg2).AND.(NAME.EQ.NAMEold)) GOTO 100
CALL MINMAXPT(P,T,Plow,Phigh,Tlow,Thigh)
GOTO(900) ICHKLIM(P,Plow,Phigh,
!DEC$ ELSE
IF ((P.GT.PMAX+0.01D0).OR.(P.LT.PMIN)) G OTO 300
IF ((T.LT.TMIN).OR.(T.GT.T5MAX+0.01D0)) GOTO 300
IF ((P.GT.P5MAX+0.01D0).AND.(T.GT.T2MAX+0.01D0)) GOTO 300
!DEC$ ENDIF
Arg1=P
Arg2=T
NAMEold=NAME
GOTO(101,102,103,104,105) IREGCHKPT(P,T,L)
101
CONTINUE
D=DPT1(P,T)
Fval=VISC(D,T)
GOTO 100
102
CONTINUE
IF (P.LT.P3MIN) THEN
TS=TSAT(P)
IF (T.LT.TS) THEN
TLIM=TMSMIN(P)
IF (T.LT.TLIM) GOTO 300
IF (P.LT.P5MAX) THEN
D=DPT2ms(P,T)
ELSE
D=DPT2(P,T)
ENDIF
ELSE
D=DPT2(P,T)
ENDIF
ELSE
D=DPT2(P,T)
ENDIF
Fval=VISC(D,T)
GOTO 100
103
CONTINUE
IF (L.EQ.0) THEN
D=DPT3G(P,T)
ELSE
D=DPT3L(P,T)
ENDIF
Fval=VISC(D,T)
GOTO 100
104
CONTINUE
GOTO 300
105
CONTINUE
D=DPT5(P,T)
Fval=VISC(D,T)
GOTO 100
100
CONTINUE
VISCOS=Fval/VIScnv(UC)
CALL STMLVLCLR
RETURN
300
CONTINUE
CALL STER(NAME,12,P,T)
RETURN
400
CONTINUE
CALL STER(NAME,42,V,T)
RETURN
900
CONTINUE
VISL=-Ilim*1.D3
RETURN
1000
CONTINUE
VISCOS=-Ilim*1.D3
RETURN
END FUNCTION VISCOS
I tried this with 10.0.027 (with _DLL defined) and got no errors. (I did have to fix up the continuation which did not seem to come across right in this post.)
What specific version of 10.0 are you using?
wkramer
I am actually using 10.1.013. I never tried to recompile this specific code under 10.0.
The code belongs to a rather large library for calculation of water and steam properties with a lot of cross references.
There are even some circular references between modules, which are resolved by repeated compilation.
So that is why I didn't post thecomplete code.
Walter Kramer
I get no errors with 10.1.013 either. At this point I suggest you attach a ZIP of your project to an issue submitted to Intel Premier Support.
You should also restructure your code so that you don't have circular module dependencies.
