29353 Discussions
Result of MERGE with polymorphic argument returns wrong dynamic type
Harald1
New Contributor II
ifort/2021.7.0 and earlier versions seem to miscompile the following example:
program p
  implicit none
  type t
     integer :: c
  end type
  type, extends (t) :: t2
     integer :: c2
  end type
  class(t), allocatable :: x, r
  integer :: i = 1
  x = t2(1,-1)
  r = merge (x, x, i == 1)
! r = merge (x, x, .true.)
  select type (z => r)
  type is (t)
    print *,"type is (t) :", z% c
  type is (t2)
    print *,"type is (t2):", z% c, z% c2
  end select
end program p
The resulting code prints:
type is (t) :           1
Note that the NAG compiler 7.1 differs here, it prints:
type is (t2): 1 -1
I would expect the latter as the expected result.
Am I missing something?
Harald
Igor_V_Intel
This problem is reproduced with the latest compiler build and escalated to the development team to be fixed.
Note that gfortran also behaves similar to ifort and ifx.
Ron_Green
This is a good little test.  a few places where the compiler is getting things wrong.  Possible the MERGE intrinsic is returning the parent type(t) instead of t2 as it should.  Also possible the select type is pulling the parent type t instead of the extended type t2 from r.
We'll get a bug report on this.
Thanks for sending this to us.
Igor_V_Intel
Harald1
New Contributor II
There is an open bug report with gfortran with a slightly enhanced version of the above test, see
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=105371#c8
Igor_V_Intel
The bug is fixed in latest Intel Fortran compiler versions, e.g. 2023.1
