Comunicados
29285 Discussões
Return exit status codes w/o extra output
tobias-burnus
Principiante
619 Visualizações
I'd like to return exit error codes if an error occures, but I don't want to output this exit error code.
Currently I use:
if(iostat /= 0) then
write(ERROR_UNIT,*) 'Cannot open file "',trim(filename),'"'
stop 1
end if
But this shows not only the error message but also a "spurious" one. If I write
stop "some error string"
or simply
stop
then the exit status code is zero.
Any ideas?
Tobias
1 Responder
Steven_L_Intel1
Funcionário
619 Visualizações
Try CALL EXIT(1) instead.
Responder
