When calling a subroutine that "exits early" due to failed input parameter value validation I get:
Unhandled exception at 0x003d0541 in vmpsI.exe: 0xC0000005: Access violation reading location 0xfffffffc.
The subroutine and calling program are attached.
o When calling the subroutine with a value of N less than 6 the runtime error is ALWAYS encountered.
o When calling with N=6 it OCCASIONALLY will return to the calling program as expected.
o ONCE I got a fatal heap corruption error.
o The SUBROUTINE follows. Note that "SomeArray" must be declared to generate the RTE.
! ThisIsBS.
! Minimal routine to generate the WTF runtime error.
SUBROUTINE ThisIsBS(S, N, D, H1Vals, H2Vals, info)
IMPLICIT NONE
! Generic two-dimensional array.
TYPE Array2d
SEQUENCE
DOUBLE PRECISION, ALLOCATABLE, DIMENSION(:,:) :: val
END TYPE Array2d
INTEGER, INTENT(IN) :: S
INTEGER, INTENT(IN) :: N
INTEGER, INTENT(IN) :: D
DOUBLE PRECISION, DIMENSION(S,S), INTENT(IN) :: H1Vals
DOUBLE PRECISION, DIMENSION(S,S), INTENT(IN) :: H2Vals
INTEGER, INTENT(OUT) :: info
DOUBLE PRECISION :: foo
INTEGER :: bar
INTEGER :: baz
! This is an array that WOULD HAVE been used later in the subroutine
! had the validations passed. So please don't submit this code to
! TheDailyWTF.com. I just ripped out EVERYTHING from the subroutine
! but this, WHICH IS BLOWING THIS DAMNED THING UP!!!!!!!!!!!!!!!!!!!
TYPE(Array2d), DIMENSION(0:N+1,1:N) :: SomeArray
! Initialize the return value.
info = 0
! Ensure the value of N is valid.
IF (N < 4) THEN
info = -1
GOTO 999
ENDIF
! Ensure the value of D is greater than zero.
IF (D < 1) THEN
info = -2
GOTO 999
ENDIF
! Ensure the value of D is a power of 2.
IF (D /= 2**INT(LOG(D*1.) / LOG(2.))) THEN
info = -3
GOTO 999
ENDIF
! Ensure the values of N and D are valid and compatible. Specifically
! D may not be "too big" for N.
IF (D > 2**INT((N-4)/2)) THEN
info = -4
GOTO 999
ENDIF
999 RETURN
END
o The calling program follows.
! Run Variational Matrix Product States (VMPS).
! This program will run the VMPS routine.
PROGRAM RunVMPS
IMPLICIT NONE
! The number of spin states per particle.
INTEGER, PARAMETER :: S=2
! The number of particles in the chain.
INTEGER :: N
! The maximum bond dimension.
INTEGER :: D
! The values of the matrix elements of the DxD one- and two-body operators that
! make up the nearest neighbor Hamiltonian (for spin 1/2):
! | <up|O|up> <up|O|dn> |
! | <dn|O|up> <dn|O|dn> |
! Here we define two arrays:
! o H1Vals for the matrix elements of the one-body operator.
! o H2Vals for the matrix elements of the two-body operator.
DOUBLE PRECISION, DIMENSION(S,S) :: H1Vals
DOUBLE PRECISION, DIMENSION(S,S) :: H2Vals
! Return value from the VMPS routine.
INTEGER :: info
! Initialize the matrix elements of the operators.
! Since the values in Fortran arrays are stored in column major order, these
! values correspond to <up|O|up>, <dn|)|up>, <up|O|dn>, and <dn|O|dn>,
! respectively. To convert these values into their 2x2 matrix we use:
! TRANSPOSE(RESHAPE(..., (/ 2, 2 /)))
H1Vals = TRANSPOSE(RESHAPE((/ -1.0d0, 0.0d0, 0.0d0, 1.0d0 /), (/ 2, 2 /)))
H2Vals = TRANSPOSE(RESHAPE((/ 0.0d0, 1.0d0, 1.0d0, 0.0d0 /), (/ 2, 2 /)))
WRITE(*,*) "I am alive."
N=4
D=3
CALL ThisIsBS(S,N,D,H1Vals,H2Vals,info)
WRITE(*,*) "I am dead."
STOP
END
My environment:
o Windows 7 Ultimate 64 bit SP1
o Visual Studio 2010 Premium
o Intel(R) Visual Fortran Package ID: w_fcompxe_2013_sp1.1.139
o Intel(R) Visual Fortran Composer XE 2013 SP1 Update 1 Integration for Microsoft Visual Studio* 2010, 14.0.0074.2010, Copyright (C) 2002-2013 Intel Corporation
Hello Richard,
In the attached example RunVMPS.f90, you have N=4, so this should reproduce the issue, but I cannot; the problem might be specific to update #1.
I can't reproduce an access violation with update #2; the output seems to be correct. Did I miss something? Does SomeArray need to be accessed to reproduce?
Otherwise, I suggest you give update #2 a try.
patrick
C:\ISN_Forums\U507067>ifort RunVMPS.f90 ThisIsBS.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.2.176 Build 20140130
Copyright (C) 1985-2014 Intel Corporation. All rights reserved.
C:\ISN_Forums\U507067>RunVMPS.exe
I am alive.
I am dead.
I am alive.
I am dead.
I am alive.
I am dead.
What are you using for compiler options?
thanks -
--Lorri
Lorri and Patrick,
Thank you for responding and I'm sorry for my tardiness in my followup.
@ Patrick: I downloaded and installed Update 2 and I am encountering the same behavior.
@ Lorri: I am compiling the Debug configuration to the Win32 platform. The compiler command line is:
/nologo /debug:full /Od /heap-arrays0 /I"C:\Program Files\Intel\Compiler\11.0\074\fortran\mkl\include" /warn:interfaces /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c
and the link command line is:
/OUT:"Debug\vmpsI.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"C:\Program Files\Intel\Compiler\11.0\074\fortran\mkl\ia32\lib" /MANIFEST /MANIFESTFILE:"F:\UCF\Physics\PHY 4912\Projects\vmpsI\Debug\vmpsI.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"F:\UCF\Physics\PHY 4912\Projects\vmpsI\Debug\vmpsI.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"F:\UCF\Physics\PHY 4912\Projects\vmpsI\Debug\vmpsI.lib" mkl_lapack95.lib mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
Thank you again for your help.
Rich
Richard,
Just for testing purposes, what happens when in your program you replace
with
H1Vals = 0.0d0
H2Vals = 0.0d0
Essentially I am checking to see if the problem resides outside of ThisIsBS
There is nothing wrong with your original statements, the suggestion simplifies the program further.
Jim Dempsey
Hi Richard,
OK, I can reproduce the access violation with the 32-bit compiler. I'll look into this more.
My initial testing was using the 64-bit version, which doesn't have the issue.
patrick
Hello Richard,
The issue with the 32-bit compiler is due to option /heap-arrays0. Let me debug this a bit more before filing a bug report with the developers.
patrick
The exception originates in libifcoremdd. The scope is greater than I first thought, it occurs for both the 32-bit and 64-bit compilers on both Windows and Linux.
Reported to the developers, tracking ID DPD200254462. I'll keep this thread updated with any news.
Patrick
This issue is now fixed in a future version of the compiler. I will update this thread when a compiler with the fix is available. The only known workaround is to not use the /heap-arrays compiler option.
Patrick
All,
I just installed Update 3, which was just published and the issue does not appear to have been resolved:
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
libifcoremdd.dll 003B0501 Unknown Unknown Unknown
libifcoremdd.dll 0036042B Unknown Unknown Unknown
vmpsI.exe 01236409 _VMPS 501 VMPS.f90
vmpsI.exe 0121CC9A _MAIN__ 53 RunVMPS.f90
vmpsI.exe 0166EDD2 Unknown Unknown Unknown
vmpsI.exe 015093BF Unknown Unknown Unknown
vmpsI.exe 015091EF Unknown Unknown Unknown
kernel32.dll 75C3EE1C Unknown Unknown Unknown
ntdll.dll 776C37EB Unknown Unknown Unknown
ntdll.dll 776C37BE Unknown Unknown Unknown
Please confirm!
Thank you.
Rich Bergmann
Update 3 is not the "future version" Patrick referred to. He meant the major release planned for later this year.
Here 'future version is the v15 compiler. It's fixed in beta v15.0 right now.
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.024 Beta Build 20140318
$ ifort -heap-arrays RunVMPS.f90 ThisIsBS.f90 && ./a.out
I am alive.
I am dead.
Patrick
Patrick,
When is the V15 compiler scheduled for release? Is this something that will be pushed as part of the update cycle?
Thank you.
Rich Bergmann
It's out now. You should receive a notification about it if your support is current - I don't think Intel Software Manager will consider this an update. You can download it from the Intel Registration Center.
The 15.0.0.108 release was released earlier this week. See the sticky note at the top of this forum index.
Hello Rich,
Intel® Parallel Studio XE 2015 (includes the v15 compilers) has been released. Your issue remains fixed in ifort-15.0.0.108:
C:\ISN_Forums\U507067\DPD200254462>ifort /debug:full /Od /heap-arrays /warn:interfaces /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs RunVMPS.f90 ThisIsBS.f90
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 15.0.0.108 Build 20140726
Microsoft (R) Incremental Linker Version 11.00.61030.0
Copyright (C) Microsoft Corporation. All rights reserved.
-out:RunVMPS.exe
-debug
-pdb:RunVMPS.pdb
-subsystem:console
-incremental:no
RunVMPS.obj
ThisIsBS.obj
C:\ISN_Forums\U507067\DPD200254462>RunVMPS.exe
I am alive.
I am dead.
Patrick
