I heard that it is possible to recover source code from a compiled, executable file (i.e. *.exe). My first question is: Is that really possible? One of our software vendors had it placed in the contract that we would not try to "reverse-compile" their software. I am wondering if that is possible with Fortran executables as well.
My second question is: How to safeguard against that? I need to provide one of our software vendors with one of my Fortran executable, so that they can write a requested application around it. Given that I am talking about financial market space, it is absolutely imperative that this vendor must not be able to "reverse-compile" my code.
Is there anyway I can do something and rest assured?
Kulachi
I'd recommend providing a statically linked release-configuration build and make sure that the traceback feature is not enabled.
Kulachi
Mostoptimized compiler are notmuch interested inpreserving your original, documented and elegant source structure and naming of variables. Numbers only will do for our compiler.
In most cases areverse compilationwilloffer youa very optimized and "unstructured" blob. In assembler OK, butwithout any recognition of the original sources, variables, processing-flow.
Clemens
It is worth noting, however, that text strings contained in your code, particularly initialisation values, may be contained in your executable in clear text. If it is critical that these not be viewable in the .exe file, then you may want to store these, e.g. as an array of ASCII integers, and create the text strings at runtime.
David
