Run-Time Check Failure #3
Les_Neilson
Valued Contributor II
Code:
program main
   integer*4 :: jnum(10)
   integer*4 :: i
   integer*4 :: j
   integer*4 :: k
   do i=1,10
      jnum(i) = i
   enddo
   j = 8
   k = maxval(minloc(jnum, MASK=jnum.eq.j))
   write(*,*) "k =", k
end
Produces four messages :
Run-Time Check Failure #3 - The variable '' is being used without being defined.
I know I can just do
k=maxval(jnum, MASK=jnum.eq.j)
but I waslooking at acode snippet of an algorithmand came across this in the process.
Can anyone explain what's wrong with the code as shown?
thanks
Les
You didn't mention that you are using /check:uninit
You've encountered two compiler bugs:
1. The variable name does not get properly reported
2. This code should not have reported an error at all
Both will be fixed as of the mid-late February update. This update will also make /check:uninit work in contexts other than running under the VS debugger.
