29649 Discussions
Run compiled openMP program inside machine which doesn't have fortran compiler
lkmdw
When I compile fortran source without openMP, I can run the executable on any machine of the same infrastructure without the need of fortran compiler / library installed. But when I compile with openMP option, it can't run on machine which doesn't have fortran compiler inside. The executable encounter the following error because the machine doesn't have the library filedyld:
Library not loaded: libguide.dylib
is this mean that it is IMPOSSIBLE to run the openMP compiled program inside machine which doesn't have fortran compiler installed in it?
Luke
Ron_Green
Quoting - lkmdw
Luke
To run on systems without Intel Fortran, compile and link the Intel libraries statically into the application:
-static-intel
And/or if you use a separate link step w/o the ifort driver, link in libguide.a statically:
-L/ -lguide
ron
lkmdw
-static-intel
-L/ -lguide
ron
It works! Thank you! I tried in Fortran 9 also, and I just found that the equal parameter for -static-intel (fortran 10) is -i-static in fortran 9. Both are okay now, thank you very much.
