Run error:
fortran_abc
Hi I've met a run problem with a fortran program. The error message is :
"forrt1: severe (408): fort: (3): Subscript #2 of the array ELINCO has a value 0 which is less than the lower bound of 1"
Does anybody know what this means and what to check to debug it?
You have an array reference, such as ELINCO(I,J), where J has the value 0, but the array is declared with that lower bound of 1. Figure out why the value of the second subscript is zero and fix it.
