29376 Discussions
Run time check on extent of dummy array
abhimodak
Hi
In the snippet below the extent of dummy array B is larger than that of A. This violates standard. But the compiler does not complain. I believe this is because of j and JMAX are just initialized in the module and hence not compiler time 'constants'. (Although in a another sense these indeed remain constant at compiler time...)
If both the declarations are changed to "Integer, Parameter :: " then compiler (11.1.035 with VS2005 on Win64 XP) will trap the error.
Is there any way this error can be trapped at run-time?
Sincerely
Abhi
Module OM
Implicit None
Integer :: JMAX = 5
Integer :: j = 3
! The two lines instead of above two will trap the error as expected.
!Integer, Parameter :: JMAX = 5
!Integer, Parameter :: j = 3
Contains
Subroutine Method(B)
Implicit None
Real(8), Intent(INOUT) :: B(JMAX)
B = 3.0d0
End Subroutine Method
End Module OM
Program Test
Use OM
Implicit None
Real(8), Allocatable :: A(:)
Integer :: ial
Allocate(A(JMAX), stat=ial)
Call Method(A(1:j))
End Program Test
Not that I can think of - the information to do so is not passed along with the call.
