Run-time diagnostics for shape mismatches in array assignments possible?
FortranFan
This is based on discussions in this thread at comp.lang.fortran: https://groups.google.com/forum/#!topic/comp.lang.fortran/OCWxsF-Tm0U.
The following simple code compiles with no errors or warnings with Intel Fortran and raises no run-time exceptions during the i=j array assignment at line 17 even though the array extents are different (as noted on the comp,lang.fortran forum, NAgFor does give a run-time error).  Run-time diagnostics is set to /check:all.  Is it possible to give some run-time diagnostics here?
module m
   implicit none
contains
   subroutine s ( i )
      !.. Argument list
      integer, intent(inout) :: i(:)
      !.. Local variables
      integer :: j(2)
      j = 42
      i = j
   end subroutine s
end module m
program p
   use m, only : s
   implicit none
   integer :: ia(1)
   ia = 0
   call s(ia)
   write (*,*) " ia = ", ia
   stop
end program p
Upon execution,
  ia =  42
Press any key to continue . . .
Steven_L_Intel1
We have a long-outstanding request for such a feature, which I would very much like to see myself. It hasn't been implemented yet.
