29234 Discussions
Run-time error connected to WRITE(*,*) without -check?
dsokus
For part of a simulation program I am writing I need to give values to elements of integer arrays (all of them are declared as allocatable in the beginning, and all of them are allocated by this part of the program).
I noticed that the final values weren't what I was expecting so I added WRITE(*,*) statements in different places in my program to be able to find out where the assignments went wrong. However, with these statements in, all the values came out all right. I !-ed some of the WRITE-s, recompiled and the values went wrong again. I repeated this a couple of times and it was consistently so... Then I added the -check option while compiling and I got no error messages, but the values are fixed again.
This leaves me puzzled. Now the program seems to work, but since it involves random numbers it can hide a lot of errors in its results if it doesn't crash from them - I would really like to understand what the problem is/was.
Zsuzsi
Here's part of the code:
do k = 1, n
barsx(k) = k
barsy(2,k) = 0
do walking = 1, totwalk
write(*,*) 'W: walker no ', walking, ' at time ', k, ' has position ', yray(walking,k)
write(*,*) 'W2: walker no ', walking, ' at time ', chosen, ' has position ', yray(walking,chosen)
if (yray(walking,chosen).eq.k) barsy(2,k) = barsy(2,k) + 1
end do
end do
Without the -check option, if the first WRITE is !-ed, the output is
W2: walker no 1 at time 5 has position 5
W2: walker no 2 at time 5 has position 5
W2: walker no 3 at time 5 has position 5
(and the same for all the rest, which is obviously wrong)
Leaving the first WRITE in, it is
W: walker no 1 at time 1 has position 1
W2: walker no 1 at time 5 has position 2
W: walker no 2 at time 1 has position 1
W2: walker no 2 at time 5 has position 3
W: walker no 3 at time 1 has position 1
W2: walker no 3 at time 5 has position 1
This is a typical symptom of use of uninitialized variables. Anything that changes instructions or moves data around can change the symptom.
dsokus
Thanks. I looked again and got down to re-doing the entire declaration/allocation/initialization stuff; then compiled and the problem stopped. I still don't know what I missed out before but now it's finally working reliably.
