Run-time error when opening/reading an ASCII file
Jacopo_C_
I am compiling a large program, which depends on several external Fortran and C libraries, on a Mac OS X 10.9.5 with Intel Fortran Compiler 15.0.1. I get a run-time error when opening an external (ASCII) file and reading it. The strangeness is that the file exist (inquired form within the program) and the that calling open gives a status = 0 (see the test program below).The simple test program below compiles and runs well on gfortran, while with ifort it gives a runtime error, which I reported below (including the backtrace, as given by gdb).
I tried to compile the same test program excluding one external library at a time, and identified which libraries are creating the run-time error. The problem is that I used these (Fortran) libraries in the past without getting any run-time error, so it's really hard to understand what could be the problem...
I also run the same test on a Linux machine with Intel Fortran 13.1.0 and I get the same error...
--------------- test program ---------------------
program test_open
  implicit none
  character(len=100)    :: fileName, line
  integer               :: status
  logical               :: exist, opened
  fileName = 'foo.txt'
  inquire( file = fileName, exist = exist )
  print *, 'exist: ', exist
  open ( 77, file = fileName, iostat = status )
  print *, 'status: ', status
  inquire( 77, opened = opened )
  print *, 'opened: ', opened
  read( 77, '(a)' ) line
  print *, 'line: ', line
  close( 77 )
end program test_open
--------------- end test program ---------------------
------- shell output --------------
 exist:  T
 status:            0
 opened:  T
forrtl: No such file or directory
forrtl: severe (29): file not found, unit 77, file /Users/jchevall/My_Codes/BANGS/build/fort.77
Image              PC                Routine            Line        Source
Stack trace terminated abnormally.
--------------- GNU debugger output ---------------------
exist: T
status:            0
opened:  T
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x0000000202aca780
0x0000000102c4d3cb in tbk_get_pc_info ()
(gdb) backtrace
#0  0x0000000102c4d3cb in tbk_get_pc_info ()
#1  0x0000000102c4cc34 in stackwalk_cb ()
#2  0x0000000102c4c971 in tbk_string_stack_signal_impl ()
#3  0x0000000102c22281 in tbk_stack_trace_impl ()
#4  0x0000000102c220b6 in tbk_stack_trace ()
#5  0x0000000102bd8cea in for__issue_diagnostic ()
#6  0x0000000102bd82de in for__io_return ()
#7  0x0000000102bfb871 in for_read_seq_fmt ()
#8  0x00000001000017e5 in test_open () at test_open.f90:20
#9  0x00000001000012be in main ()
(gdb)
jimdempseyatthecove
The error statement showing ".../fort.77" indicates that the open statement did not execute.
Try commenting the open statement, then retyping the statement (*** do not copy and paste ***).
Also, if you are using fixed form file format, assure that the open begins at/after column 7 (*** do not precede with tab ***)
If you are using free form then disregard the prior directive.
Did your build emit an error, which you did not observe, and then you inadvertently ran a different (older) output file?
With the text that came out of the program this seems unlikely.
Jim Dempsey
Steven_L_Intel1
I haven't been able to reproduce the problem with the code shown. I agree with Jim that the message indicates that the file was not open on the unit at the time of the READ.
