the following code crashes at runtime with ifort/ifx:
program p
implicit none
class(*), allocatable :: x(:)
x = foo()
call prt (x)
deallocate (x)
! up to here all is fine...
associate (var => foo())
call prt (var) ! <- crash here
end associate
contains
function foo() result(res)
class(*), allocatable :: res(:)
res = [42]
end
subroutine prt (x)
class(*), intent(in) :: x(:)
select type (x)
type is (integer)
print *, x
class default
stop 99
end select
end
end
I get:
ifx intel-associate-unlim-poly.f90 -g -traceback && ./a.out
ifx: remark #10440: Note that use of a debug option without any optimization-level option will turnoff most compiler optimizations similar to use of '-O0'
42
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
libpthread-2.31.s 00007FF2B7937910 Unknown Unknown Unknown
a.out 0000000000404D58 prt 18 intel-associate-unlim-poly.f90
a.out 00000000004049AE p 9 intel-associate-unlim-poly.f90
a.out 000000000040425D Unknown Unknown Unknown
libc-2.31.so 00007FF2B775824D __libc_start_main Unknown Unknown
a.out 000000000040418A Unknown Unknown UnknownThe code works just fine with NAG.
Harald
This is an interesting testcase. Gfortran 13.0 gets an ICE just trying to compile it.
the runtime crash by ifx is a bug. We'll get a bug report created for this case. Thanks @Harald1 for sending this to us.
the bug ID is CMPLRLLVM-55090
@Harald1 this bug is fixed in the 2024.1.0 compiler. I just confirmed the fix in the released compiler.
Hmmm, it still crashes at runtime here with the exact same traceback as given in the original post:
% ifx intel-associate-unlim-poly.f90 -g -traceback -V && ./a.out
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.1.0 Build 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Intel(R) Fortran 24.0-1472.3
GNU ld (GNU Binutils; SUSE Linux Enterprise 15) 2.41.0.20230908-150100.7.46
42
libpthread-2.31.s 00007FF0450B4910 Unknown Unknown Unknown
a.out 0000000000404D68 prt 18 intel-associate-unlim-poly.f90
a.out 00000000004049BE p 9 intel-associate-unlim-poly.f90
a.out 000000000040426D Unknown Unknown Unknown
libc-2.31.so 00007FF044ED724D __libc_start_main Unknown Unknown
a.out 000000000040419A Unknown Unknown UnknownHas it been fixed in a version newer than this?
Ooppps! There's a typo in the "Fixed Version" field of the bug report. This one is fixed in 2024.2 that is planned for mid 2024.
Sorry for the misinformation.
