29649 Discussions
Runtime crash with polymorphic types
MR
The attached code crashes when compiled with ifort 15.0 . The intended output should be (from a gfortran run)
$ ./test
 T
           1
 T
           1           2
module m1
 implicit none
 type, abstract :: c_abs
 end type c_abs
 type, extends(c_abs) :: t_cnt
  class(c_abs), allocatable :: f
 end type t_cnt
end module m1
module m2
 use m1, only: c_abs, t_cnt
 implicit none
 type, extends(c_abs) :: t_a
  integer, allocatable :: i(:)
 end type t_a
 type, extends(c_abs) :: t_b
  integer :: ndata
  type(t_cnt), allocatable :: data(:)
 end type t_b
contains
 pure function get_data(var) result(dat)
  class(t_b), intent(in) :: var
  type(t_cnt) :: dat(var%ndata)
   dat = var%data
 end function get_data
end module m2
program p
 use m1
 use m2
 implicit none
  type(t_b) :: b
  type(t_cnt), allocatable :: cnt(:)
  b%ndata = 1
  allocate( b%data( b%ndata ) )
  allocate( t_a :: b%data(1)%f )
  select type( a => b%data(1)%f )
   type is(t_a)
    allocate( a%i(2) )
    a%i = (/ 1 , 2 /)
  end select
  cnt = get_data( b )
  write(*,*) allocated(cnt)
  write(*,*) size(cnt)
  write(*,*) allocated( cnt(1)%f )
  select type( a => cnt(1)%f )
   type is(t_a)
    write(*,*) a%i
  end select
end program p
Kevin_D_Intel
Thank you for the report. I will investigate and post again soon.
Kevin_D_Intel
The crash is reproducible with our 15.x and 14.x compilers; however, the program runs successfully with the upcoming 16.0 compiler in the Parallel Studio XE 2016 release. The program also crashes using the initial 16.0 Beta and runs successfully using the 16.0 Beta Update 1 compiler. As a final test, I used the latest 16.0 development compiler and find the program also runs successfully.
While it appears a fix in the Beta update 1 has led to the correct program behavior, I have been unable to identify any previously reported defect that I could definitely say represented the issue has been fixed.
At this time it appears the issue is fixed in the upcoming 16.0 compiler and we can revisit the investigation if it resurfaces in a future compiler. I’m sorry I could not provide a more definitive resolution for you than this.
MR
OK, thank you.
Marco
