text output in opengl
chunky_lover_23
in an attempt to recreate the useful but now defunct glutbitmapcharacter routine, I'm attempting to use the fwglUseFontBitmaps routine as described at: https://msdn.microsoft.com/en-us/library/windows/desktop/dd374392(v=vs.85).aspx
Unfortunately the code fails  (okay=false, istatus = 0) when the fwglUseFontBitmaps function is called.  Any ideas ?
Please ignore the font stuff  - this was me starting to code up the NeHe tutorial - but since I cant get the fwglUseFontBitmaps to work I abandoned all hope.
subroutine setup_winfont(fontbase)
! routine to setup windows fonts for future output - based on arial font
use IFWINA
use IFOPNGL
integer(k_glint) :: fontbase
integer(HANDLE) :: hDC ! Device Context
integer(HANDLE) :: hRC ! OpenGL Context
integer(HANDLE) :: hWnd ! Window
integer(HANDLE) :: hinstance
integer(HANDLE),save :: hFont=0
integer(HANDLE),save :: oldFont=0
integer(HANDLE) :: hmemDC
integer font_height, istatus
logical keys(256)
logical okay
hmemDC = CreateCompatibleDC (hDC)
istatus= SelectObject (hmemDC, GetStockObject (SYSTEM_FONT))
write(*,*)'istatus ',istatus
write(*,*)'fontbase is ',fontbase
okay= fwglUseFontBitmaps(hmemDC, 0, 255, 1000)
write(*,*)' okay = ',okay
Stephen_Sutcliffe1
Try creating a display list first.
eg
integer :: fbase
fbase = fglGenLists(255)
and then refer to this in your call to fwglUseFontBitmaps(hmemDC,0,255,fbase)
Hope this helps
Steve
JVanB
Valued Contributor II
There is a more complete example in Norman Lawrence's book. A perhaps more complete example, but designed to be compatible with gfortran rather than ifort can be found at http://home.comcast.net/~kmbtib/Fortran_stuff/gridview.zip in the gridview.f90 file, subroutine MakeFont.
chunky_lover_23
thanks to all who replied.  I've managed to get the text to display.  Here is the code in case anyone else needs it..  The winmods  module is a stripped down version of the ringmods module contained in the opengl examples.
subroutine setup_winfont(iheight)
use IFWINA
use IFOPNGL
use winMods
logical okay
font_height=-iheight  ! use minus to get nearest character height
fontbase = fglGenLists(255)
hFont = CreateFont (font_height, & !
				    0,0,0, &
					FW_NORMAL, FALSE,FALSE,FALSE, &
					ANSI_CHARSET, OUT_DEFAULT_PRECIS, &
					CLIP_DEFAULT_PRECIS, DEFAULT_QUALITY, &
					DEFAULT_PITCH .OR. FF_DONTCARE, &
					"arial")
istatus = SelectObject(hDC, hfont)  !          // Selects The Font We Want
! istatus= SelectObject (hDC, GetStockObject (SYSTEM_FONT))
okay= fwglUseFontBitmaps(hDC, 0, 255, fontbase)
end
subroutine print_text(output_str,x_pos,y_pos,fontbase)
use IFWINA
use IFOPNGL
! routine to disply text at the position with the current font
character*(*) output_str
call fglRasterPos2f(x_pos, y_pos)
call fglPushAttrib(GL_LIST_BIT)             ! Pushes The Display List Bits     ( NEW )
call fglListBase(fontbase)
call fglCallLists(len(output_str), GL_UNSIGNED_BYTE, loc(output_str)) ! Draws The Display List Text
call fglPopAttrib()
end
