use dfwinty
TYPE (T_SHELLEXECUTEINFO) SHINFO
character($maxpath) :: bitmapfile, windir, paintdir
integer*4 ret, ghWnd, hPaint, hPaintMenu, hPaintMenu1, hPaintMenuitem
logical retlog
! Find the windows directory, stored in environment variable "WINDIR"
! Could also use "SystemRoot" environment variable
LENGDIR=GETENVQQ("WINDIR", WINDIR)
! MSPaint is usually in the system32 sub-folder
PAINTDIR=WINDIR(1:LENGDIR)//'\system32\mspaint.exe'C
SHINFO%cbSize= sizeof(SHINFO)
SHINFO%Fmask= SEE_MASK_NOCLOSEPROCESS
SHINFO%hwnd= ghWnd
SHINFO%lpVerb= loc('open'c)
SHINFO%lpFile= loc(PAINTDIR)
SHINFO%lpParameters=loc('"'//bitmapfile//'"'c )
SHINFO%lpDirectory= loc('C:'C)
SHINFO%nShow= SW_HIDE
retlog=ShellExecuteEx(SHINFO)
if(SHINFO%hInstapp.lt.32) then
ret=MESSAGEBOX(ghWnd,'Failed to find//launch MSPaint'C, &
'Problem saving the plot as JPEG file using MSPaint'C, &
MB_ICONEXCLAMATION .OR. MB_OK)
MainWndProc=0
return
endif
! minimise this application's window so MSPaint's 'Save As' dialog can be seen
ret=SendMessage(ghWnd,WM_SYSCOMMAND, SC_MINIMIZE,0 )
call sleepqq(1000) ! give program time to load
hPaint=FindWindow_g1('MSPaintApp'c, NULL ) ! Get the handle to MSPaint window
hPaintMenu=GetMenu(hPaint) ! Get the handle to the main menu
hPaintMenu1=GetSubMenu(hPaintMenu,0) ! Get the handle to the first drop-down menu
! Get the handle to the 4th (zero-based) item in the drop-down menu
hPaintMenuItem=GetMenuItemId(hPaintMenu1,3)
! Send a command that this menu item has been selected...this should launch the 'Save As' dialog
ret=SendMessage(hPaint,WM_COMMAND, MAKEWPARAM(hPaintMenuItem,0), NULL)
! wait for display of Save As dialog and waste time in the loop
! for as long as the 'Save As' dialog exists...
call sleepqq(1000)
do while(FindWindow_g1('#32770(Dialog)'c, 'Save As' ).ne.NULL)
end do
call sleepqq(1000) ! make sure data is saved before sending command to exit MSPaint...
ret=SendMessage(hPaint,WM_CLOSE, 0, 0 ) ! close MSPaint after 'Save As' dialog is completed
ret=SendMessage(ghWnd,WM_SYSCOMMAND, SC_RESTORE,0 ) ! Restore application's window
retlog=SYSTEMQQ('DEL '//bitmapfile) ! Delete unwanted bitmap file, if desired
Greg
Message Edited by anthonyrichards on 06-27-2005 02:24 AM
i have used the shown source code to use mspaint to save bitmaps (jpg, png) since a long time. We have changed our operating system towards Win 7 Prof 64 bit. Now the shown source code is not working.
I do use the following source code:
[bash] LENGDIR=GETENVQQ("WINDIR", WINDIR)
! ShellExecute Parameter definieren
!SHINFO%hwnd= xWnd
SHINFO%lpParameters=loc(bitmapfile )
! MsPaint starten
bSt=ShellExecuteEx(SHINFO)
call sleepqq(500)
ghPaint=FindWindow_g1('MSPaintApp'c, NULL ) ! Get the handle to MSPaint window
hPaintMenu=GetMenu(ghPaint) ! Get the handle to the main menu
i = SetCursor(hSaveCursor) !/* Restores previous cursor */
! Use 'PostMessage' to prevent locking up of this dialog waiting for return from MSPAINT...
iSt=PostMessage(ghPaint,WM_COMMAND, MAKEWPARAM(hPaintMenuItem,0), NULL)
call sleepqq(500) [/bash] Does anyone had the same problem? Any solution?
Thanks in advance
Frank
in the old days the program mspaint has been startet in the background. The 'save_as' dialog was shown.
Now there is no mspaint in the taskmanager and no 'save_as' dialog.
Thanks in advance
Frank
Why use Paint? Wouldn't it be easier, and less prone to future problems (no Paint), if you incorporate a JPEG compression/decompression library that should be available on sourceforge.net (e.g. http://gnuwin32.sourceforge.net/packages/jpeg.htm)
Jim Dempsey
37 lines of FORTRAN code, excluding comments, IS pretty easy I think. I agree it all falls over when MSPAINT is no longer issued. If the menu options change, or window class names change, those problems should be 'easily' dealt with. I just thought, why not use code that exists to do the job, especially as MSPAINT offers so many image formats for free.
I would like to know if MSPAINT exists on the poster's system? If it does, perhaps it is a problem with window class id's or menu options. If not, then that's that and a freeware solution is required (for those of us not into image processing at the nuts and bolts level).
For further diagnostics, I think it would be wise to add and activate some MessageBox messages at certain stages through the calling code to gve information about return codes etc as the program code executes.
The only thought I had was whether the handles were still integer(4) or whether they should be integer(HANDLE) on the Win7 64 bit system. I'm pretty sure mspaint.exeexists on my Win 7 laptop (in c:\windows\system32) but I haven't been able to run the given code on it yet.
$0.02
Les
With the proper library this may be one line of code, and you will never have to changethe programwhen:
MSPAINT goes away
MSPAINT is given a new face (drop down menues change)
parlez-vous franais
To protect against this .AND. use MSPAINT, I would suggest the user writes the internal format to file as-is, then calls an external program, preferably a script file, that performs the conversion file to file (optionally deleting input file too). The initial conversion program can be MSPAINT or other convient tool. Later if MSPAINT changes or your requirements change. you simply change thescript file to use that other program/utility/library.In this way, the compiled FORTRAN program need never to be updated (with regard to format exchange).A conversion utilityprogram will likely be much smaller than MSPAINT, so the overhead to write the temp file will be returned by the lower load time of the conversion program.
Finding an appropriate library and integrating it into y0ur application may take a few hours of web searching. You will have to be the judge as to how many hours this will save you (or the next person supporting the program) in the future.
Jim Dempsey
