29106 Discussions
SELECT TYPE statement and parenthesized selector
Harald1
New Contributor II
the following code is accepted by NAG but rejected by ifort/ifx:
program p
  type t
     integer :: a
  end type
contains
  subroutine s(x)
    class(t) :: x(:)
    select type (y =>  x)  ! OK
    type is (t)
    end select
    select type (z => (x)) ! rejected by ifort/ifx
    type is (t)
    end select
  end
end
 I get:
% ifx -what ifort-select-type.f90
 Intel(R) Fortran 23.0-1769.01
ifort-select-type.f90(11): error #8247: Selector in SELECT TYPE statements must be polymorphic value.
compilation aborted for ifort-select-type.f90 (code 1)
 Likely a bug...
Steve_Lionel
I think it is a bug, but a subtle one:
C1164 (R1155) The selector in a select-type-stmt shall be polymorphic.
"If an expression is a polymorphic primary or defined operation, the type parameters and the declared and dynamic types of the expression are the same as those of the primary or defined operation."  (F018 10.19.1)
and then:
"If a primary is a parenthesized expression, its type, type parameters, and shape are those of the expression." (F2018 10.1.9.2)
So here, (X) is a parenthesized expression, and the expression is X. X is a polymorphic primary.
I admit to being a bit uncomfortable with this and will check on this.
Steve_Lionel
I verified with Malcolm Cohen, standard editor, that indeed, if X is polymorphic, so is (X). The text I quoted above supports this.
Harald1
New Contributor II
Barbara_P_Intel
Since @Steve_Lionel and Malcom concur that this is part of F2018 and should not report an error message, I filed a bug, CMPLRLLVM-52979.
Curiously, gfortran 9.4.0 ICEs.
