SETDCBRUSHCOLOR
Brooks_Van_Horn
Has the function SETDCBRUSHCOLOR been deprecated and if so how do you change the brush color?
Brooks
Steve_Lionel
No, it hasn't. It ought to be defined in module GDI32, but isn't. You can define your own interface, for example:
interface
function SetDCBrushColor (hdc,color) BIND(C,NAME="SetDCBrushColor")
!DEC$ ATTRIBUTES DEFAULT, STDCALL :: SetDCBrushColor
use IFWINTY
integer(ULONG) :: SetDCBrushColor
integer(HANDLE), intent(IN), value :: hdc
integer(ULONG), intent(IN), value :: color
end function SetDCBrushColor
end interface
Paul_Curtis
Valued Contributor I
Interesting...  I use CreateSolidBrush(), which is defined in GDI32, works perfectly.  Note that with this API you have to explicitly clean up with DeleteObject(hbrush) when done.  The MSDN chat on SetDCBrushColor is unclear (to me, at least) about who does the memory management when a stock system brush is replaced with a user brush, so be careful not to create small memory leaks which would be difficult to detect.
