SGdemo/SciGraph in QuickWin
moyhega
I am new to Intel Fortran.
I had a computer crash and lost my VF compiler version 6 . I have another 6 version and installed it.
My app is a SGdemo/SciGraph in QuickWin. I have recompiled SG demo (no errors) and then recompiled SciGraph (no errors) and included SCIGraph.lib in my quickwin app. Compiling my quickwin app gives me, "DEC$ DESCRIPTOR/REFERENCE ATTRIBUTE valid only on interface dummy. [SGDATA]".
GSData is in SGDemo which compiles, and is put into my Scigraph which compiles without this error.
Could this be double nesting problem with Interfacing? I can't find a missing INTERFACE/END INTERFACE statement.
This mixes with MSVC 6.0 with no problems.
Also, I understand these are old versions. This morning my IT group said that I am being updated to new Intel Fortran. But I'd like to fix this problem before tackling these new upgrade ones.
Thank you.
ps. I am also looking for training on the new compiler.
Which file and line is the error reported on? I have only CVF 6.6, so if something changed between 6.0 and 6.6 that is lost.
Links you should look at are Migrating from CVF and Introduction to Intel Visual Fortran.
moyhega
Thanks for the reply. I have a file in my quickwin app named Misclib.f which reports the error. In that file is a subroutine which has a "USE SCIGRAPH" statement. I do not get a line number in my error message.
Would you attach a ZIP of your application (sources and project files) to a reply here? I'd then see if I could reproduce the problem. You're still building this with Digital Visual Fortran, right?
moyhega
Thank you for replying. Yes, I am still building with DVFortan and MSVC/C++ 6.0. Not sure about attaching the zip file. I will have to check. Thanks.
p.s. Tnx for the automatic Green Belt Award.
