STATUS_STACK_BUFFER_OVERRUN encountered
Kreienkamp__Frank
After a break of several years i am back again to use IVF. I am working on an old (converted) CVF  quickwin project consisting approx. 50 fortran-files. The program compiles in debug and release (both win32) mode without any warning and error. When I start the program it stops immediately with the message:
No more. Unfortunately I have no idea where to search for the problem. Ideas will be appreciated. I havened found an idea based on an search in the forum.
I am using: Intel® Parallel Studio XE 2018 Update 1 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 18.0.0037.14,
Thanks in advance
Frank
Lorri_M_Intel
I have a couple of suggestions for things to look at.
First, when you converted your old program from CVF to Intel Fortran, the converter will add /iface:cvf by default to the command line.
However, any callback routines used by some of the QuickWin routines MUST be declared with default calling sequence, not 'cvf-compatible' calling sequence.
To find your callback routines, I'd check your usage of APPENDMENUQQ, MODIFYMENUROUTINEQQ, INSERTMENUQQ, maybe some others?  Those were the ones I found in the online help just looking for a few minutes.    Once you find your callback routines, you can add
!DEC$ ATTRIBUTES DEFAULT :: routinename
just after the routine declaration.
Of course -- you can remove the /iface:cvf that was added by the converter; you really only need that if you have existing/unchanged libraries that you need to call.
                        --Lorri
andrew_4619
"without any warning and error." There are many warnings e.g. check interfaces  that are not on as standard. I would consider the check-all options.
Kreienkamp__Frank
Hello Andrew_4619,
I have already activated the check-all option. Unfortunately no warnings  present.
Frank
Kreienkamp__Frank
Hello Lorri,
I havened found the line /iface:cvf in my files. I think the person which has done the convert from CVF back in 2012 already removed this line.
We do not add libraries. It is all pure Fortran with just a tiny bit of quickwin.
We have not used APPENDMENUQQ, MODIFYMENUROUTINEQQ, INSERTMENUQQ in the code. We have used GETHWNDQQ, GETWSIZEQQ, MESSAGEBOXQQ, SETWSIZEQQ, GETDRIVEDIRQQ and CHANGEDIRQQ. Do I have to declare interfaces for those?
It is 'USE DFLIB' inside to code. Should I change it to 'USE IFLIB'?
Frank
andrew_4619
The error I think is corrupting the stack, a common cause is writing past the end of s character string. If you have a break point set at the first line of your code do you get there in the debugger? If so just step line by line to find the crash.
Lorri_M_Intel
No, you don't need to change USE DFLIB; that mod file 'use's the correct, other mod files, including the one that defines the entry points for the QuickWin routines.
Please try Andrew's suggestion to start at the beginning of your program, and see if you can find the crash.
Kreienkamp__Frank
unfortunately Andrews way is not working. The error occurs before the first line with an possible break point.
May includes like INCLUDE 'limits.inc'(for variables) , INCLUDE 'actual.cmn' (for common blocks) including definitions of variables and common block can cause the problem? Those lines (actually 20 includes) are placed before and inside the variable definition.
as example (incomplete lines) :
C **********************************************************************
IMPLICIT NONE
C specifications:
C ********************* list of common blocks **************************
C a) actual field limits
C * local fields
REAL vgsave(N1MAX) , wfsave(N1MAX) , bfdsave(N1MAX)
C c) additional blocks of 3d model
C * general parameters, grid structure
INCLUDE 'geom.cmn'
C ***************************** Local variables ************************
REAL ath(0:NXMAX,0:NYMAX,NZMAX) , fluxx(NXMAX)
REAL CC(NXMAX,NYMAX,NZMAX) , CC1(NXMAX,NYMAX,NZMAX)
C ********************** Equivalent fields *****************************
EQUIVALENCE (ath,dd)
REAL DTDpsi2m(NXMAX,NYMAX,NZMAX)
Frank
John_Campbell
New Contributor II
Your problem could be large local arrays, potentially like "ath", "CC" and "CC1" which may have been static allocation in 2012. They could now be overflowing the available stack. These might be solved by:
* increasing the stack size, or
* moving these arrays from the stack to heap ( see recent posts), or
* make them static by moving them to a module or COMMON, or
* making them allocatable
* use compile options to change dynamic arrays to static/saved
The first step should be to identify these large local arrays and determine if they could be causing the problem.
my preference is use ALLOCATE as it identifies your action to move large local arrays.
Kreienkamp__Frank
Good mooring John,
Most big arrays are dimensioned by numbers out of an include file. I have reduced those numbers to small values. No change. I have also changed the Configuration Properties - Linker - System - Heap Reserve Size and Stack reserve size the large values. No change.
Unfortunately must arrays are used in equivalence statements.
I looks like an large rewrite before I can use allocatable arrays.
Frank
Dastous__Jean-Bernar
I had the same error with a simple fortran code that I moved recently into a new solution in Intel® Parallel Studio XE 2017 Update 4 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2012, Version 17.0.0047.11. This program had allocatble arrays in it.
The same program worked fine before. After a few hours of trying to find the issue, I simply recreated a new solution with the same fortran source code in a different folder on my computer (Under Windows 7) - the error disappeared and the program worked as before. I don't understand why - seems like a bug ? So if you get this error, maybe try what I did.
