29389 Discussions
SUBMODULE/STDCALL/BIND(C)/Unresolved external
andrew_4619
!  subm_link_prob.f90
module mymod
    use ifwin
    implicit none
    INTERFACE
        MODULE FUNCTION FRED(HDLG) BIND(C,NAME='FRED')
            !DEC$ ATTRIBUTES STDCALL :: FRED
            INTEGER(INT_PTR)                   :: FRED
            INTEGER(HANDLE),INTENT(IN), VALUE  :: HDLG
        END FUNCTION FRED
    END INTERFACE
end module mymod
submodule (mymod) mymod_subs
    implicit none
    contains
    module function FRED( hDlg) BIND(C,NAME='FRED')
        implicit none
        integer(INT_PTR)                    :: FRED
        integer(HANDLE), intent(in), VALUE  :: hDlg
        FRED = 1_INT_PTR
    end function FRED
end submodule mymod_subs
program subm_link_prob
    use ifwin
    use mymod
    implicit none
    integer (INT_PTR) :: iret
    print *, 'Hello World'
    iret = FRED(0_handle)
    print *, iret
end program subm_link_prob
1>------ Build started: Project: subm_link_prob, Configuration: Debug Win32 ------
1>Compiling with Intel(R) Visual Fortran Compiler 16.0 [IA-32]...
1>subm_link_prob.f90
1>Linking...
1>subm_link_prob.obj : error LNK2019: unresolved external symbol _FRED@4 referenced in function _MAIN__
1>Debug\subm_link_prob.exe : fatal error LNK1120: 1 unresolved externals
What is the problem?
The issue with conflicting binding labels is DPD200411167. I was pointed to 16.2p1 in the standard where it says, "An entity of the program shall not be identified by more than one binding label."
andrew_4619
Having looked at 2008 I also note:
C1250 (R1225) If MODULE appears in the prefix of a module subprogram and a binding label is specified, it shall be the same as the binding label specified in the corresponding separate interface body.
I ended up in this situation BTW as I had not noticed that the program I wrote to convert create interfaces from modules uppercased  the bind names.....
Thanks for that too.
Issue DPD200382120 (wrong decoration for submodule procedure with BIND(C)) will be fixed for 17.0 product release.
andrew_4619
Cheers.
There were a number of DPDs relating to submodules and most of the key ones seem to be closed now. One that causes me some continual irritation (mainly because I am set it my ways of working in VS)  is DPD200375967 which is about source folds not working with "module function" and "module subroutine" which means folds are not present with a large proportion of my code now . I suspect it is perhaps just a case of adding some new keywords to a list in the Fortran integration. Would that be likely to make 17.0?
Andrew, I have asked the developers for an update on that one.
Andrew, the developer tells me that they hope to have the submodule/expand issue fixed in either 16.0.4 or 17.0.1.
andrew_4619
Good news, thanks. I am loving SM's and the lack of build cascades it is saving loads of time but I am drinking less coffee..... :-)
Didn't you hear? Coffee is now good for you again (unless you drink it very hot)! Have more coffee!
andrew_4619
Yes that was yesterday hot drinks (>65C) might cause cancer. Who drinks coffee at the temp. it hurts!
The STDCALL issue (DPD200411145) will be fixed in an update to 17.0 (not in the initial release.)
