Samples Feed
Zhanghong_T_
Dear administrator,
When I update the Intel OneAPI to 2022.03, the following message box popped up every time I build a project:
The samples feed is empty.
What could lead to this problem?
MWind2
New Contributor III
A similar question is how turn the notification off?
MWind2
New Contributor III
I had downloaded the samples and tried to change location in oneAPI options in VS2022, and it would crass VS2022. Disabled one API Menu.
JohnNichols
Honored Contributor I
It happened to me, I had to switch it off.  Wonder why.
Devorah_H_Intel
@Zhanghong_T_ wrote:
Dear administrator,
Could you elaborate on which Toolkit is that? Base or HPC or both? I have never seen this type of message, but I normally install only HPC Toolkit on my machine.
Devorah_H_Intel
I will take it back. I do see this pop up when opening VS2022. I also see the following message on the top of the VS
Arjen_Markus
A colleague found the solution somewhere on the Internet. Here is the receipe:
  • In Visual Studio open the Extensions/Manage extensions menu item
  • Select the category Installed
  • Look for "Intel oneAPI Menu & Samples"
  • Press the "Disable" button
  • The message will not appear again
Of course, this assumes that you do not need the samples.
JohnNichols
if you reinstall you have to do it again, sorry I was aware of the solution, but thanks for finding it again.
