I am starting to work with ScaLAPACK library and I am trying to make and execute the ScaLAPACK tests, as given in Intel Cluster Toolkit Tutorial, on page 74 in chapter: "Getting started with the Intel Math Kernel Library Cluster Edition".
I am following the instructions from the Tutorial: I go to
/opt/intel/ict/2.0/cmkl/8.0.1/tests/scalapack
and then type:
gmake libem64t F=intel90 mpi=intelmpi20 LIBdir=/opt/intel/ict/2.0/cmkl/8.0.1/lib/em64t
Gmake does its job, it compiles the source files and then sends out execution commands of built programs (for 4 nodes, I have 8) and everything seems fine. No error messages.
But, when I look for the output *.txt files in theteste/scalapack/source/TESTING directory,
there isn't any. It is as if no output files were created during the
execution of programs.
I am running the tests as root, so I think there shouldn't be any permission problems.
What can be done to solve the problem?
and then type:
