I've noticed that in some circumstances postings in this forum are enclosed in a window with scrollbars. I haven't determined what those circumstances are exactly. However, the vertical scrollbar trims off the rightmost character or two on each line, making it annoying and difficult to read.
Couldn't the scrollbars be added outside the text display area, or have the text display area sized a bit narrower than the window so that there will be room for the scrollbar without hiding text?
This is with Windows Explorer 7.0.5730.13 under Windows XP SP3.
This is a recent change and a fix for a problem in the way that IE formats HTML. Without the scrollbar, some text would be cut off at the bottom. I have not heard of the problem you describe and will let the forum developers know.
