29280 Discussions
Seg fault caused by allocate statement with source variable
lopes8070
Another compiler catastrophoc error. This time there is an allocate statement with a source definition. There are 3 classes in play. 2 classes (C,H) extend a third (D). There is a pointer (same thing happens with allocate attribute) to an object of class D defined in the main program. I then allocate the pointer with the source defined as one of either C or H (Trying to them make it of that type which is known only at runtime.
Source code attached.
Upon compilation:
echo "Compiling with F90=ifort -O0 -g -fp-stack-check -traceback -gen-interface -warn interface and CC=icc"
make compile TARGET=demo \
F77="ifort -O0 -g -fp-stack-check -traceback -gen-interface -warn interface " F90="ifort -O0 -g -fp-stack-check -traceback -gen-interface -warn interface " CXX="icc" \
CC="icc" LINKER="ifort -O0 -g -fp-stack-check -traceback -gen-interface -warn interface " \
FFLAGS="" CFLAGS="-O2 -g"
echo "Compiling" Program.f90
Compiling Program.f90
ifort -O0 -g -fp-stack-check -traceback -gen-interface -warn interface -c Program.f90
: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for Program.f90 (code 3)
make[1]: *** [Program.o] Error 3
make: *** [ifort] Error 2
Kevin_D_Intel
I planned on posting about both. I want to ensure the fix is in the 11.1 branch in advance of code cutoff for update 6. That will give both of us peace of mind.
Kevin_D_Intel
My apologies. I lost track of my commitment to reply earlier. I did justconfirm the fix for (Internal tracking id: DPD200148482 - internal error with SOURCE=) is in 11.1 Update 6.
