I get a segmentation fault when calling a type bound procedure from a coarray object.
In the following code, if the line 41 is commented, the seg. fault disappears.
! ifort -coarray main.f90; ./a.out
Module Block_Container_Class
implicit none
Type :: Block_Container_Type
integer :: idum
contains
procedure ,public :: TBProcedure
End Type
contains
Subroutine TBProcedure( This )
class(Block_Container_Type) ,intent(inout) :: This
write(*,*) " [TBProcedure]: Inside"
End Subroutine
Subroutine NormalProcedure( This )
type(Block_Container_Type) ,intent(inout) :: This
write(*,*) " [NormalProcedure]: Inside"
End Subroutine
End Module
Module Mesh_Class
use Block_Container_Class
implicit none
private
public :: Mesh_Type
Type :: Mesh_Type
type(Block_Container_Type),allocatable :: Blocks[:]
contains
procedure ,public :: Construct
procedure ,private :: MeshTBProcedure
End Type
contains
Subroutine Construct( This )
class(Mesh_Type) ,intent(inout) :: This
call This%MeshTBProcedure()
End Subroutine
Subroutine MeshTBProcedure( This )
allocate( This%Blocks
We'll take a look - thanks.
This problem is our issue DPD200416083. Thanks for reporting it.
