I read a file using the following code
program read_eof_test use, intrinsic :: ISO_FORTRAN_ENV IMPLICIT NONE real (real64) :: a, b, c, d, e integer :: fn_fid, ios, in_shot_fid character (len = 511) :: in_shot_fn in_shot_fn = 'file_orig.dat' open (newunit = in_shot_fid, file = trim (in_shot_fn), status = 'old') do read (in_shot_fid, *, iostat = ios) a, b, c, d, e print *, a, b, c, d, e print *, ios if (ios < 0) exit if (ios > 0) stop 'ERROR reading file.' enddo close (in_shot_fid) end program read_eof_test
which is compiled using this makefile
DEBUG = -O0 -g -traceback -C -debug all GENERAL = -m64 -fpp -fopenmp $(DEBUG) -e08 all: read_eof_test.x read_eof_test.x: read_eof_test.o ifort read_eof_test.o $(GENERAL) -o read_eof_test.x read_eof_test.o: read_eof_test.f90 ifort $(GENERAL) -c read_eof_test.f90
Usually, this works fine. However for some files, a segmentation fault is caused on end of file. For example, a file ending with these lines
34 167.36134 20.07923 0.7672 370268674.194989 41 167.36220 20.06267 0.7792 370268674.319989
will give
34.0000000000000 167.361340000000 20.0792300000000 0.767200000000000 370268674.194989 0 41.0000000000000 167.362200000000 20.0626700000000 0.779200000000000 370268674.319989 0 8624.19499000000 1.50000000000000 166.945570000000 26.3012800000000 -2.48660000000000 0 forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source read_eof_test.x 000000000040B12D Unknown Unknown Unknown libpthread-2.22.s 00002B2F9D958B20 Unknown Unknown Unknown read_eof_test.x 000000000045A483 Unknown Unknown Unknown read_eof_test.x 000000000041D616 Unknown Unknown Unknown read_eof_test.x 0000000000402DAC MAIN__ 18 read_eof_test.f90 read_eof_test.x 0000000000402B1E Unknown Unknown Unknown libc-2.22.so 00002B2F9DD896D5 __libc_start_main Unknown Unknown read_eof_test.x 0000000000402A29 Unknown Unknown Unknown
If I then change only one character in the file
34 167.36134 20.07923 0.7672 370268674.194989 41 167.3622 20.06267 0.7792 370268674.319989
the file is read fine
34.0000000000000 167.361340000000 20.0792300000000 0.767200000000000 370268674.194989 0 41.0000000000000 167.362200000000 20.0626700000000 0.779200000000000 370268674.319989 0 41.0000000000000 167.362200000000 20.0626700000000 0.779200000000000 370268674.319989 -1
So, I guess this is somehow related to the specific file, but I do not see why the segmentation fault occurs sometimes. I have a large amount of files that need to be read, and many of them exhibit this behaviour, but I do not have a way to tell in advance.
The example file is attached. It is quite long, but I cannot shorten it without modifying the outcome.
Dear Robin,
I do get the segmentation fault as you have described with ifort v17.0.8, but not with v18.0.5 or v19.0.1. (neither do I get it with gfortran 5.4 nor nagfor 6.2 nor PGI v18.7) So could it be that you are using an old Intel compiler? (and this is a problem that has been known to Intel and has been fixed meanwhile)
Hi Jürgen, thanks for testing it. I am indeed using ifort version 18.0.0. I will see if I can update my compiler.
