29386 Discussions
Segmentation fault for reshape of large array
XiaOaiX
program arrayreshape
  implicit none
  integer, parameter:: N=1000
  integer :: i,j
  real(8), allocatable, dimension(:,:):: a, b
  allocate(a(N,N))
  allocate(b(N,N))
   a=reshape([(1._16,i=1,N**2)],[N,N])
   b=reshape([(100._16,i=1,N**2)],[N,N])
end program
Using ifort (IFORT) 2021.6.0 20220226, it can be built without error, but there will be segmentation fault:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
reshapeLargeMatri 0000000000404C7A Unknown Unknown Unknown
libc.so.6 00007F71C1EE48E0 Unknown Unknown Unknown
reshapeLargeMatri 000000000040387F Unknown Unknown Unknown
reshapeLargeMatri 0000000000403842 Unknown Unknown Unknown
libc.so.6 00007F71C1ECF290 Unknown Unknown Unknown
libc.so.6 00007F71C1ECF34A __libc_start_main Unknown Unknown
reshapeLargeMatri 0000000000403725 Unknown Unknown Unknown
Is this a bug? Changing to N=500, it runs without problem.
jimdempseyatthecove
You are likely having stack overflow. Possible solutions:
a) Increase stack size
b) use option heap arrays
c) replace reshape with DO loop
Jim Dempsey
andrew_4619
What Jim Said, additionally did you really intend kind=16 for for 1D arrays assigned to a kind=8 array? You can guess all manner of temp arrays need to be created on the stack for these lines.
