29648 Discussions
Segmentation fault + subroutine vs function interface
diedro
Dear all,
I have a Segmentation fault (core dumped) problem.
When I run my code and I use a function I get a segmentation fault, but only when I use a matrix and a vector with more than 90 elements. I have checked the code but I am not able to find the problem. Could it be the interface problem. Because I allocate some vector and matrix directly in the function. This is my code:
MODULE MOD_SOLVE_COMPLEX_LINEAR_SYSTEM
INTERFACE
      FUNCTION SOLVE_COMPLEX_LINEAR_SYSTEM(A,B,m,n,trans) RESULT(X)
         USE lapack95
         IMPLICIT NONE
         COMPLEX , DIMENSION(M,N) , INTENT(IN) :: A      !matrix to solve
         COMPLEX , DIMENSION(N)   , INTENT(IN) :: B      !known term
         INTEGER,                   INTENT(IN) :: m      !
         INTEGER,                   INTENT(IN) :: n      !
         CHARACTER*1,               INTENT(IN) :: trans  !type solver
         COMPLEX , DIMENSION(N)                :: X      !solution
      ENDFUNCTION
ENDINTERFACE
ENDMODULE MOD_SOLVE_COMPLEX_LINEAR_SYSTEM
USE MOD_SOLVE_COMPLEX_LINEAR_SYSTEM
USE lapack95
IMPLICIT NONE
INTEGER, DIMENSION(N)   :: IPIV
COMPLEX, DIMENSION(M,N) :: LA
INTEGER   :: info
 LA=A
 X=B
! some operations......
ENDFUNCTION
What do you think?
Thanks a lot
Kevin_D_Intel
Probably the automatic arrays IPIV and LA are exhausting the available stack space. You could try the -heap-arrays option or convert those into alloctable arrays and allocate them at the start of the routine and deallocate at the end.
INTEGER, ALLOCATABLE, DIMENSION(:)   :: IPIV
COMPLEX, ALLOCATABLE, DIMENSION(:,:) :: LA
ALLOCATE(IPIV(N)
ALLOCATE(LA(M,N)
You can refer to Determining Root Cause of Segmentation Faults SIGSEGV or SIGBUS errors for additional information about using -heap-arrays and other possible causes/solutions of segmentation faults.
A couple of links in the article are current broken, the corrected links are included below:
The Doctor Fortran article Don’t Blow Your Stack!
The PDF presentation on Fortran Compiler Use of Temporaries
mecej4
Apparently, you are using the large local array LA (and B) to guard against the overwriting of A by its L-U factors by the actual solver called in the function SOLVE_COMPLEX_LINEAR_SYSTEM (actual code not shown). If so, consider allocating these arrays in the caller of SOLVE_COMPLEX_LINEAR_SYSTEM, setting LA=A and X=B in that caller, and calling the actual solver with these copies as arguments.
diedro
Dear all,
thanks a lot.
I have created a subroutine ad as suggested I preallocate IPIV and LA.
Thanks a lot
