Segmentation fault with debug
Sagan__David
The program is listed below.
Using: ifort (IFORT) 14.0.1 20131008
Platform: Linux
Compiling with "ifort test.f90" works fine. Compiling with "ifort -g test.f90" gives:
cesr109:~/linux_lib/test> ./a.out
 Calling addr_info...
Segmentation fault
module db_info_mod
  type note_struct                ! for multiline notes
    character(132), pointer :: line(:)
  end type
  type header_row_struct
    character(40) :: name
    character(160) :: str
    character(8) :: encoding        ! HEX, etc
    character(160) :: descrip
    character(160) :: descrip2       ! additional (paranthetical) description
    logical in_xfile
  end type
  type record_struct
    integer index
    character(160) :: col(50)
    logical :: in_xfile
    logical :: exists
    integer :: ix_parent_rec = -1   ! corresponding parent record index.
  end type
  type property_struct
    logical :: in_xfile             ! saved in xfile?
  end type
  type card_info_struct
    type (header_row_struct) header(100)
    type (record_struct) rec(256)
    type (property_struct) col(50)
    type (note_struct) notes(50)               ! multiline notes
    character(132) lines(200)                    ! storage for the notes
  end type
contains
subroutine addr_info ()
implicit none
type (card_info_struct) :: info_xxx(50)
print *, 'In addr_info'
end subroutine addr_info
end module
program test
use db_info_mod
print *, 'Calling addr_info...'
call addr_info()
end program
Sagan__David
Looks like a memory problem since if I change: type (card_info_struct) :: info_xxx(50) to: type (card_info_struct) :: info_xxx(2) Then the program runs.
FortranFan
Looks like you're running into the limits of stack size on your system.
Can you use an allocatable array for info_xxx instead of a fixed size one?
Otherwise, look into using the -heap-arrays option or increasing the stack size.
