29273 Discussions
Segmentation fault with multiple large arrays declared COMMON
catp
I am getting a segmentation fault error using seven (7) large arrays declared as COMMON variables (see =CASE 1= below); No segmentation fault occurs if I comment out the COMMON declaration line in the same program (See =CASE 2= below); And even more interesting, if I change the code such that I use only one array declared as COMMON variable, even if I set the dimensions of this array so it is larger that the sum of all the seven arrays in my previous case, it does not give a segmentation fault!! (see =CASE 3= below).
I am using Intel EM64T Fortran Compiler 8.1 Build 20040922 on SuSE Linux 9.0 (x86-64) with 7433 MB RAM. I compiled with the options ifort -i_dynamic -traceback -mcmodel=large
Could anybody help me understand why this is happening? Please see below the details about the three cases:
Cat
=== CASE 1 ===
PROGRAM MAIN
INTEGER MAXEL
PARAMETER (MAXEL=100000)
INTEGER MAXGP
PARAMETER (MAXGP=4)
INTEGER MAXLAY
PARAMETER (MAXLAY=21)
COMMON KARRAY1,KARRAY2,KARRAY3,KARRAY4,KARRAY5,KARRAY6,KARRAY7
DOUBLE PRECISION KARRAY1 (MAXEL,MAXGP,MAXLAY,9)
DOUBLE PRECISION KARRAY2 (MAXEL,MAXGP,MAXLAY,9)
DOUBLE PRECISION KARRAY3 (MAXEL,MAXGP,MAXLAY,9)
DOUBLE PRECISION KARRAY4 (MAXEL,MAXGP,MAXLAY,3)
DOUBLE PRECISION KARRAY5 (MAXEL,MAXGP,MAXLAY,3)
DOUBLE PRECISION KARRAY6 (MAXEL,MAXGP,MAXLAY,3)
DOUBLE PRECISION KARRAY7 (MAXEL,MAXGP,MAXLAY,9)
INTEGER I, J, LOP
LOP = 0
IF (LOP .EQ. 0) THEN
DO I = 1, 10
DO J = 1, 9
KARRAY1(I,1,1,J) = 1.0D0
KARRAY2(I,1,1,J) = 1.0D0
KARRAY3(I,1,1,J) = 1.0D0
CALL SLEEP(10)
KARRAY7(I,1,1,J) = 1.0D0
ENDDO
DO J = 1, 3
KARRAY4(I,1,1,J) = 1.0D0
KARRAY5(I,1,1,J) = 1.0D0
KARRAY6(I,1,1,J) = 1.0D0
ENDDO
ENDDO
END IF
CALL SLEEP(60)
END
So, the 7 COMMON arrays KARRAY1- KARRAY7 should use 100000*4*21*45*8/1024 = 2953125 KB. Instead I get forrtl: severe (174): SIGSEGV, segmentation fault occurred
I used the SLEEP() calls above just to give me enough time to run cat /proc//status which returned the following:
State: S (sleeping)
Tgid: 11827
Pid: 11827
PPid: 2485
TracerPid: 0
Uid: 228 228 228 228
Gid: 101 101 101 101
FDSize: 64
Groups: 101
VmSize: 2180640 kB
VmLck: 0 kB
VmRSS: 1216 kB
VmData: 2165836 kB
VmStk: 12 kB
VmExe: 4 kB
VmLib: 4172 kB
=== CASE 2 ===
On the other hand, if I comment out the COMMON declaration line, the same code runs fine without any errors. Here is the result of running it and examining the process with cat /proc/ProcID/status:
State: S (sleeping)
Tgid: 13823
Pid: 13823
PPid: 2485
TracerPid: 0
FDSize: 64
Groups: 101
VmSize: 2968140 kB
VmLck: 0 kB
VmRSS: 1280 kB
VmData: 2953336 kB
VmStk: 12 kB
VmExe: 4 kB
VmLib: 4172 kB
=== CASE 3 ===
PROGRAM MAIN
< span>INTEGER MAXEL
PARAMETER (MAXEL=199)
INTEGER MAXGP
PARAMETER (MAXGP=100)
INTEGER MAXLAY
PARAMETER (MAXLAY=100)
COMMON KARRAY1
DOUBLE PRECISION KARRAY1 (MAXEL,MAXGP,MAXLAY,600)
INTEGER I, J, LOP
LOP = 0
DO I = 1, MAXEL
DO J = 1, 600
KARRAY1(I,100,1,J) = 1.0D0
ENDDO
ENDDO
END IF
CALL SLEEP(60)
END
So this one COMMON array KARRAY1 should use 199*100*100*600*8/1024= 9328125 KB (No Segmentation errors, even if KARRAY1 is much larger than the sum of the 7 common arrays in the previous cases)
>cat /proc/12692/status:
State: S (sleeping)
Tgid: 12692
Pid: 12692
PPid: 2485
TracerPid: 0
FDSize: 64
Groups: 101
VmSize: 9343140 kB
VmLck: 0 kB
VmRSS: 4580 kB
VmData: 9328336 kB
VmStk: 12 kB
VmExe: 4 kB
VmLib: 4172 kB
joseph-krahn
Another unexpected result:
When I tried to compile your first test code, I get a segfault in the *compiler* usinf the 32-bit version 9.1. Maybe the size is too lage for 32-bit, but a compiler crash is always bad.
Compiler version and crash message:
Intel Fortran Compiler for 32-bit applications, Version 9.0 Build 20051201Z Package ID: l_fc_c_9.0.031
fortcom: Severe: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
If I reduce the size of MAXEL, it compiles and runs successfully, so it is likely a compiler bug. A reasonable fix is to upgrade, but it looks like there may be a related bug in the newer version.
Some things to try:
Have you tried an named common?
What if you put the common statement after the array declarations?
You can always declare one named common for each array.
Steven_L_Intel1
The IA-32 compiler failure I have reported to the developers.
Did you build your test case with "-mcmodel medium"? This is required to get large data address space.
catp
Steve,
I used ifort -i_dynamic -traceback -mcmodel=large. Is "-mcmodel medium" a better option?
Cat
Steven_L_Intel1
For you, I would say medium is a better choice, unless your code is so large it requires more than 2GB of address space. "medium" lets you have big address space for data but not code.
If you can't solve the problem, file a report to Intel Premier Support.
