29391 Discussions
Segmentation fault with the matrix transpose function
Phy_Soham
It works for the ( nxn ) matrix when n is smaller, and the result and argument of the transpose function are the same.
For larger n, it produces a segmentation fault.
A way out is transposing through a temporary matrix, as shown in the code below.
I am using Intel Fortran Compiler Classic version: ifort (IFORT) 2021.7.0 20220726.
gfortran (v-10.4.0) does not produce the segmentation fault.
Am I missing something in the Fortran standards?
program TransposeBug
    implicit none
    integer, parameter          :: dp = selected_real_kind(15, 307)
    real(dp), dimension(:, :), allocatable      :: Mat, Mat_tmp
    integer                                     :: n
    ! ================================ Small vlaue of n works ================================ !
    n = 81
    allocate( Mat(n, n) )
    call random_number( Mat )
    Mat = transpose( Mat )
    write(*, *) "Transpose of Matrix complete"
    deallocate( Mat )
    ! ==================== Large vlaue of n works through temporary matrix =================== !
    n = 11838
    allocate( Mat_tmp(n, n) )
    Mat_tmp = transpose( Mat )
    Mat = Mat_tmp
    deallocate( Mat_tmp )
    deallocate( Mat )
    ! ============================= Large vlaue of n do not works ============================ !
    n = 11838
end program TransposeBug
Result:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
libpthread-2.17.s  00007F47E6766630  Unknown               Unknown  Unknown
a.out              000000000040572C  Unknown               Unknown  Unknown
a.out              000000000040429D  Unknown               Unknown  Unknown
libc-2.17.so       00007F47E63AB555  __libc_start_main     Unknown  Unknown
a.out              0000000000404176  Unknown               Unknown  Unknown
jimdempseyatthecove
Try enabling heap-arrays to avoid stack overflow.
Jim Dempsey
jimdempseyatthecove
Jim Dempsey
Phy_Soham
jimdempseyatthecove  . No segmentation fault with "-heap-arrays" flag.
