29643 Discussions
Compiler bug with submodules and procedure pointers
OP1
New Contributor III
This code fails to compile with the latest ifort 2021.6.0 and ifx 2022.1.0 compilers.
Note that if the definition of the procedure pointer is in the parent module, the code compiles just fine.
Sigh...
MODULE M
IMPLICIT NONE (TYPE, EXTERNAL)
! Declaring P_ACTUAL here works.
!PROCEDURE(P), POINTER :: P_ACTUAL
INTERFACE
    MODULE SUBROUTINE P
    END SUBROUTINE P
END INTERFACE
END MODULE M
SUBMODULE (M) SM
! Declaring P_ACTUAL here fails.
END SUBMODULE SM
SUBMODULE (M : SM) P
CONTAINS
    MODULE SUBROUTINE P
    IF (ASSOCIATED(P_ACTUAL)) THEN
    END IF
    END SUBROUTINE P
END SUBMODULE P
Barbara_P_Intel
I don't get an ICE with this reproducer with either ifx or ifort.
Can you please send the version number you get when you add the compiler option "-what"?
$ ifort -what -c icy.f90
 Intel(R) Fortran 2021.6.0-1299
icy.f90(22): error #6404: This name does not have a type, and must have an explicit type.   [P_ACTUAL]
icy.f90(22): error #6106: Not a valid argument for ASSOCIATE or SELECT TYPE.   [ASSOCIATED]
compilation aborted for icy.f90 (code 1)
$ ifx -what -c icy.f90
 Intel(R) Fortran 22.0-1296
OP1
New Contributor III
Barbara - the code indeed does not produce an ICE. But it should still compile without any errors, and that's not the case.
Barbara_P_Intel
Ah! You had me thinking ICE after the earlier issue. THANKS!
Barbara_P_Intel
I filed a bug report for you, CMPLRLLVM-37576.
Barbara_P_Intel
The reproducer now compiles without error with the latest Fortran compilers, ifort 2021.7.0 and ifx 2022.2.0. Both are part of the oneAPI HPC 2022.3 Toolkit that was released earlier this month.
Give the new compilers a try!
