Segmentation fault
mathieu52
The following program creates segmentation fault
under ifort 8.1, ifort 9.0 but not under ifc 7.0
PROGRAM BUGSEARCH
CALL gls_corstep_tile(1044574)
CONTAINS
SUBROUTINE gls_corstep_tile(Jend)
integer, intent(in) :: Jend
integer, parameter :: r8 = selected_real_kind(12,300) ! 64-bit
real(r8), dimension(Jend) :: var1
! real(r8), dimension(1044574) :: var1
Print *, 'The program has finished'
END SUBROUTINE gls_corstep_tile
END PROGRAM
The segmentation fault does not happen if 1044574 is replaced by a smaller value and if the value of Jend is replaced directly by its value.
The problem happen under linux 2.4.20-8 and linux 2.6.8-2-686-smp
Mathieu
You are exceeding the stack limit for the large automatic array. Try this instead:
PROGRAM BUGSEARCH
CONTAINS
real(r8), allocatable, dimension(:) :: var1
allocate (var1(jend))
END PROGRAM
This will use dynamic allocation for the variable and should allow much larger allocations without worrying about stack size. The array will be automatically deallocated on exit of the subroutine.
