29602 Discussions
Select case block vs array of function pointers
FilippoMonari
Hi all,
I would like some advice about the following. I have a quite big SELECT CASE block where cases are unique integers. The block includes about 200 cases representing different functions. I was wondering if I could get any benefit in terms of speed by replacing the big SELECT CASE block with an array pointers pointing to functions to apply. Thanks in advance.
Filippo
JohnNichols
Honored Contributor I
Pick the one that is easy to maintain - although 200 seems a lot
FortranFan
@FilippoMonari ,
Since your question is general Fortran, you may want to consider posting it at Fortran Discourse site (and possibly also USENET based comp.lang.fortran) for wider feedback:
By the way, here's a long thread toward a similar discussion at comp.lang.fortran a while ago that may help you with some pointers:  https://groups.google.com/g/comp.lang.fortran/c/6uROcAIvPcQ/m/ULl1Muz0CAAJ
Ultimately I think you'll have to figure out what works best for you.
FortranFan
